Chassis dyno ?
#1946034
11/06/15 12:39 AM
11/06/15 12:39 AM
Posts: 4,677 On the parachute mount
n20mstr
Anyone tune on a chassis dyno ?
I will probably have my car back together right about when it's cold and snowing....thinking about chassis dyno to get it dialed in. Any one do this ?
....BAD A$$ STREET CAR.....
Re: Chassis dyno ?
[Re: n20mstr]
#1946048
11/06/15 01:00 AM
11/06/15 01:00 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
If you have a high stall converter you will have limited info. Forget the numbers until the slip is minimal. The actual hp & torque numbers don't mean anything - just look at differences run to run.
One time I made 26 pulls in a half day. At the end of the day initial tune was spot on and cracked a head while tuning.
Re: Chassis dyno ?
[Re: n20mstr]
#1946067
11/06/15 01:34 AM
11/06/15 01:34 AM
Posts: 707 California
BigDaddy440
California
I'm a huge fan of chassis dynos. They allow you to for the most part dial in your a/f ratio and at the same time, find out what kind of power you're making across the power band. Some people have criticism for chassis dynos and believe there are too many variables to accurately gauge real power output...and I don't want to entertain that argument here. What I can say is that chassis dynos are great for tuning and I believe there is enough consistency with dyno brands, like dynojet, to feel confident about the power numbers the dyno reports. Converting these numbers to engine power at the flywheel is just an estimate based on drive train loss, but one could argue that (knowing) what you have at the wheels is the more important number.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Chassis dyno ?
[Re: n20mstr]
#1946069
11/06/15 01:37 AM
11/06/15 01:37 AM
n20mstr
I am dealing with a new engine combo to me, yes I want to get the a/f dialed in and the timing dialed in. I'd rather do it on a chassis dyno than on the track, still got to deal with getting 275's to work.
Re: Chassis dyno ?
[Re: n20mstr]
#1946143
11/06/15 06:43 AM
11/06/15 06:43 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I use a chassis dyno a LOT. Did an EFI conversion on a TS car earlier in the year. The quickest pass it had ever made with carbs and two nitrous kits was a 4.16 in good air..........I did all the EFI tuning on the chassis dyno, including lighting both stages of nitrous. He put it in the trailer, headed to Dallas for PDRA season opener, with NO track time. First pass, right off the trailer with the chassis dyno tune, was a 4.17 @ 171. Has since been a 4.10 on two kits in really good air
I also tune Chad's car on the chassis dyno. It has 4 kits, but have only sprayed the two small ones on the dyno. It makes over 1400 to the tire on the first two
Re: Chassis dyno ?
[Re: 506RR]
#1946298
11/06/15 02:30 PM
11/06/15 02:30 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
We tuned our Duster on a chassis dyno. Got the tune close, but didn't keep beating it to death to find every last HP.
However, when we went to the track we had a good starting point, which we wouldn't have been near as close to without dyno'ing it first.
Ended up with 650 whp on motor, and 905 whp on nitrous. Gets ya close and IF there`s an issue, it`s easier than in the car to fix.......
Re: Chassis dyno ?
[Re: HDNMOPERS]
#1946531
11/06/15 08:05 PM
11/06/15 08:05 PM
Posts: 702 Southern Alberta
Uberpube
Southern Alberta
Do your research and talk to some dyno shops. The dyno must be a load dyno for sure Maybe you should do some research on Dynojets before posting.
Re: Chassis dyno ?
[Re: n20mstr]
#1946712
11/07/15 12:52 AM
11/07/15 12:52 AM
Uberpube
Southern Alberta
It makes my f**%ing blood boil when I read its inertia only about Dynojets.. I had an early model 248 , and it was loading as they all were. It had proportional air brakes that I could load the car against and hold it at tire speed, engine speed or % load.. I don't think the people I bought it from even knew it was capable of load holding. The new dynojets have the same load hold, or you can order eddy brake, that gives you real time torque output. The roller is 2 feet in diameter, its weighted, but serves several purposes: first it allows the the dyno to have a fixed calibration for cross dyno repeatability, that can't be monkeyed with, second is for contact patch, and it doesn't destroy sidewalls of the tires with excessive loading, really an important aspect when it comes to road racing.
Re: Chassis dyno ?
[Re: Monte_Smith]
#1946830
11/07/15 11:34 AM
11/07/15 11:34 AM
Uberpube
Southern Alberta
You can "lie" to a chassis dyno. All you are trying to do is control the rate of acceleration. So if you tell the dyno that the car weighs 4000lbs, when it really only weighs 3000lbs, you will get more control. Many ways to do it.
On the "adjustable" dyno's that's probably true.. The dynojet has no inputs beside the firing cycle degrees to set the tach input. I guess you could try putting the weather station stack in a toaster oven if you were so inclined to mess with the output, but the altered data would be naked in the run file.
Re: Chassis dyno ?
[Re: mshred]
#1946837
11/07/15 11:43 AM
11/07/15 11:43 AM
Uberpube
Southern Alberta
I brought my car to a dyno once, it was a "load" dyno...Every change I made to the car on the dyno that had it pick up there, slowed it down like crazy at the track. Needless to say, I am not a big fan of dynos, unless of course the load dyno had something to do with it Great way to sell dyno time, change correction factors, show the customer a positive gain no matter what the car really did..
Re: Chassis dyno ?
[Re: Uberpube]
#1949696
11/11/15 11:32 PM
11/11/15 11:32 PM
n20mstr
I brought my car to a dyno once, it was a "load" dyno...Every change I made to the car on the dyno that had it pick up there, slowed it down like crazy at the track. Needless to say, I am not a big fan of dynos, unless of course the load dyno had something to do with it Great way to sell dyno time, change correction factors, show the customer a positive gain no matter what the car really did.. My car has a racepak. I don't care what the dyno says honestly. I just st want to tune my a/f , timing and keep upping my nitrous until I have a clean "NO" jet tune in my plate. I really don't care what the dyno says..... That being said,Mehta type of tie down points are required on my car .?
Re: Chassis dyno ?
[Re: Monte_Smith]
#1950628
11/13/15 06:13 PM
11/13/15 06:13 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Can somebody please explain that one to me? If the car is stationary, what does the dyno care what it weighs?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Chassis dyno ?
[Re: n20mstr]
#1950667
11/13/15 07:39 PM
11/13/15 07:39 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
The rollers provide resistance, so I am assuming that you can change that and change how it corrects itself.
Brett Miller W9 cnc'd heads STR Chassis fabraction
