If the rear has some miles on it, you may have to replace some bearings. The pinion seal on my '01 2500 started leaking a few months back. I thought it was just gonna be a quick seal R&R job, but when I got under it I realized there was a lot of pinion gear movement. Ended up replacing both pinion bearings and carrier bearings.
