Re: Factory Lifters
[Re: AlexP]
#1945727
11/05/15 04:10 PM
11/05/15 04:10 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
Just run stock SRT8 6.1 lifters. They'll take 8000 rpm all day long. There isn't a good replacement yet. $12 apiece, mechanic next door bought one yesterday
Re: Factory Lifters
[Re: Max Weg]
#1945800
11/05/15 06:47 PM
11/05/15 06:47 PM
Triple Threat
Renton Washington
Is there any difference between a non MDS 5.7 lifter and the 6.1 lifters?
Re: Factory Lifters
[Re: Max Weg]
#1945818
11/05/15 07:20 PM
11/05/15 07:20 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think Mopar changed part #'s to include non-MDS and 6.1 under the same #. These are Johnson Hylift versions with full circlips, which is a nice addition even to factory lifters. http://www.ebay.com/itm/PERFORMANCE-RACE-HEMI-MOPAR-DODGE-CHRYSLER-JEEP-5-7-6-1-ROLLER-LIFTERS-NON-MDS-/321843082888?hash=item4aef57b688:g:PqgAAOSw7NNUI6uQ&vxp=mtr
Mopar to the bone!!!
Re: Factory Lifters
[Re: Max Weg]
#1946093
11/06/15 02:28 AM
11/06/15 02:28 AM
Triple Threat
Renton Washington
Steff posted a link once for the circlips. Someone might have saved it, i'll look around.
Re: Factory Lifters
[Re: Max Weg]
#1950534
11/13/15 03:24 PM
11/13/15 03:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just had a thought perhaps someone else could capitolize on...
Why not take the MDS lifters apart and shim them so they don't totally collapse, like perhaps keep .200 lobe lift so they could be shut down at low speeds to reduce lift and duration by activating and deactivating the solonoids? You could augment low speed driving with a smaller cam and have an RPM switch re-activate them at a certain RPM for full lift/duration. Or perhaps a WOT switch to activate them at or near full throttle? You would just need to set them up so all 8 cylinders are doing the same thing and it could be seemless.
Re: Factory Lifters
[Re: Max Weg]
#1950613
11/13/15 05:41 PM
11/13/15 05:41 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The MDS is only on 4 of the cylinders.
Lots goes into the MDS deal, way more than just the lifters shutting down. It shuts the injectors off and changes the throttle angle when in MDS mode.
68 Barracuda Formula S 340
Re: Factory Lifters
[Re: Max Weg]
#1950844
11/14/15 12:46 AM
11/14/15 12:46 AM
72Swinger
Nebraska
Just use the non MDS "good" oem 6.1-5.7-6.4 lifters and let it eat. I didnt convert to a Gen III to have a 4 banger at ANY time lol! These things are killa...
