Re: The ole 727 slip yoke!!
[Re: screamindriver]
#1945438
11/05/15 01:42 AM
11/05/15 01:42 AM
RapidRobert
they go on aways then you have to orient it slightly till the splines start to engage then go on further. it takes the weight of the shaft & a good shove to start it/remove it on the splines but no mallet should be needed. got another 727 you can check it on?
[Re: Kern Dog]
#1945734
11/05/15 04:16 PM
11/05/15 04:16 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Correct, the dead spline allows air to move from the air pocket behind the output shaft to the tailhousing...prevents "air hammering" on the output shaft.
