Re: Pics needed to custom valve cover breathers
[Re: 340_Dart]
#1944936
11/04/15 11:44 AM
11/04/15 11:44 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I went with the bolt on Moroso breather than seconds as an oil fill.2 breathers and 2 Moroso puke tanks.
[Re: 340_Dart]
#1944990
11/04/15 01:35 PM
11/04/15 01:35 PM
Posts: 10,038 MN
JERICOGTX
MN
Thank you for posting the pictures of the Moroso breathers. I've been looking at those, but just wasn't sure about them. I'll be ordering a set for the new car.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1944997
11/04/15 01:54 PM
11/04/15 01:54 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Make sure you put both breathers towards the front and install nice baffles or you make end up installing a catch can like I just had to do
[Re: 340_Dart]
#1945206
11/04/15 08:08 PM
11/04/15 08:08 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
MUST put baffling in valve covers under breather hole before they go to anything else, whether its a breather tank/catch can etc. The vapors need to get out but the oil needs to stay.
Mopar to the bone!!!
[Re: 72Swinger]
#1945254
11/04/15 09:37 PM
11/04/15 09:37 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Forward location, large tube size. These tubes go very high into the filters that you see. This was on my worn out boosted engine. No problems with oil drips or leakage. Keep the splash gaurds inside the valve covers as far from the tube opening as possible. The more free flowing large area the better. Baffling that restricts air flow creates velocity... velocity pics up oil.
