I would run narrow full groove main bearings, I use the Seal Power or Federal Mogul # 4094 M and run the clearances at or above .0030, same thing on the rods if you running the 2.200 rod journal sizes use .0025+. I like and use the high volume oil pumps and cut the bypass spring to get the pressures where I want them (you can use the adjustable regulator like your planning on and get the same results
) with hot oil using the 10 lbs. per 1000 RPM rule
You may find that the motor will want to continue to make power above 5600 RPM
Which brand and size intake port size aluminum heads are you using?
