Cam Bearing Replacement?? #1940147
10/28/15 03:57 AM
10/28/15 03:57 AM
Iowa
76dodgeboy Offline OP
Iowa
Any tips or tricks? Tool should be here by Sunday. Thanks
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1940160
10/28/15 04:57 AM
10/28/15 04:57 AM
Install them one at a time, not all at once before checking the cam fit tsk Install the rear one first(the smallest one)and then slide the cam in to see if it spins good, if so do the next one and so on. If you run into a tight one, which you will eventually if you do enough Mopar V8 blocks, then you can use a bearing knife carefully to remove the shining high spots, a little at a time until that bearing will allow the cam to rotate freely thumbs Good luck, let us know how your first one goes work Use the tapered alignment guide to get the tool centered on all of them that you can use it on up, the front can be a challenge shruggy
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1940431
10/28/15 03:32 PM
10/28/15 03:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Install the rear 2 from the front and the front 2 from the rear , center can be done from either end.
Put the 2 end ones in first and install the cam and make sure it spins freely then install the rest one by one.
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1940531
10/28/15 06:06 PM
10/28/15 06:06 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The last set I put in were Speed Pro and the cam fit better than any other bearings I have used.
2011 Drag Pak Challenger
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941030
10/29/15 02:30 PM
10/29/15 02:30 PM
Iowa
Iowa
Is it possible to do with the rotating assembly in?
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941031
10/29/15 02:34 PM
10/29/15 02:34 PM
It might be tuff shruggy I don't do them that way, I installed them on the engine stand with the main bearing bores with the caps off pointing up, I install the last(the smallest one) bearing on the tool and install it, on the rest I install them onto the tool in the block so I don't damage them while working the tool through the other cam journals with the bearings installed on the tool twocents
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941497
10/30/15 02:44 AM
10/30/15 02:44 AM
Iowa
Iowa
I wasn't near the motor when I asked that. I gotta pull the crank frown
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941540
10/30/15 08:59 AM
10/30/15 08:59 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I always find the worst part of an engine build is the cam bearings. There has to be a better way than that universal crap with the rubber bands around it. Chevy has sized knocker blocks. Someone must make them for Mopar.
[image][/image]
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941566
10/30/15 10:32 AM
10/30/15 10:32 AM
an8sec70cuda Offline
You can do it w/ the rotating assembly installed.
I've always done them the way JohnRR said...front 2 from the rear, rear 2 from the front and the middle from either end.
Kenny...The worst part of a MOPAR engine build is the cam bearings. Doesn't seem to be as much of an issue w/ other blocks. Guess it's a cam tunnel bore size or alignment issue? I never had nearly as much trouble w/ other makes as I did w/ the Mopar big blocks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cam Bearing Replacement?? [Re: sgcuda] #1941597
10/30/15 11:44 AM
10/30/15 11:44 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I made my own tool for BBM and use Dura-Bond bearings after having trouble with another brand being tight years ago. Make sure the bores are clean and free of any nicks or burs from knocking the old bearings out. I have installed them with rotating assembly together twocents thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Cam Bearing Replacement?? [Re: MoParFish] #1941602
10/30/15 11:59 AM
10/30/15 11:59 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Big block Mopar and small block Ford are two of the worst engines out there for replacing cam bearing and NOT getting a tight one but it can be done. Like others have said, install and test each one or you may be VERY sorry. The more you do the easier it gets just like almost every other job.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941611
10/30/15 12:22 PM
10/30/15 12:22 PM
Iowa
Iowa
Original plan was regasket and toss a cam in and swap motors. I didnt like the idea of just replacing the bad headgasket on the motor in the truck. So after looking at the motor last night and seeing no way to do the bearings with crank in Im just going to replace the headgasket and rebuild the motor thats torn down to a shortblock and swap when done. Thanks for the input.
Re: Cam Bearing Replacement?? [Re: pittsburghracer] #1941644
10/30/15 01:59 PM
10/30/15 01:59 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
The FE Ford can be a pia too
72 Plymouth Roadrunner 11.08@123.25
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941646
10/30/15 02:06 PM
10/30/15 02:06 PM
Weird, I think I had more trouble w/ tight bearings in sb chevies than I did w/ Fords. Had very few give any trouble at all really. Mostly just knock em in and go. The Mopars, on the other hand, seemed like I always had to massage them to get the cam to spin freely.
CHIP
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941716
10/30/15 05:34 PM
10/30/15 05:34 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
We just installed a set of dura bond bearings in my 440 with the rotating assembly in.
I had to have the #2 cam journal polished as that was the tight one for my block.
I was in the process of doing a cam swap and the original #2 bearing was too tight from the get go and had given up the ghost. (It was replaced at some time as the other 4 bearings had penastars on them and #2 was aftermarket)
unions....the folks who brought you the weekend!
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1941994
10/31/15 05:05 AM
10/31/15 05:05 AM
Iowa
Iowa
I don't see how you can get them into place with the crack still in. Being my first time I'm not wanting to chance anything and I need the truck back on the road before snow starts flying here.
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1942012
10/31/15 09:05 AM
10/31/15 09:05 AM
sgcuda Offline
sgcuda  Offline
Moparfish; I like that setup. I should probably look into having a set of knockers machined up for my installer. Great idea. Thanks.
[image][/image]
Re: Cam Bearing Replacement?? [Re: 76dodgeboy] #1942057
10/31/15 11:34 AM
10/31/15 11:34 AM
P
Porter67 Offline
Porter67  Offline
P
My set has a separate one for each bearing, bought it off ebay like 15 years ago.
Im more lucky then good it seems since the only cam ive had bind was a used on that didnt bind when it was new.
I also have only used the mopar performance (who makes them?) cam bearings so maybe they might be more forgiving.
