EZ EFI or Carb? #1940698
10/28/15 10:28 PM
10/28/15 10:28 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Guys I am currently in a position to buy a carb or F.A.S.T EZ EFI for my W2 340 Cuda. I have been running my 650 Demon for now, but it needs more fuel. I figure I went with W2 heads, ported and polished by someone we know grin .... roller cam and rockers, TTI headers and I already installed an MSD distributor (6AL ign) and a wide band A/F setup so why not finish what I want. I'm getting the itch to to inject it. I've heard mixed reviews. Please give me your thoughts and experience. If I get the fuel delivery right and avoid and voltage drops I was hoping I'd be happy. My intial set up probably won't be an intank pump (I'll need to modify mine buy one set up....choices?). Thoughts??
Re: EFI or Carb? [Re: UCUDANT] #1940713
10/28/15 10:51 PM
10/28/15 10:51 PM
IN
ahy Offline
ahy  Offline
IN
I run EFI on my '70 Challenger and love it. I passed through your neck of the woods on a road trip IL-CA-IL not too long ago. It did great in the mountains and deserts. No issues at 7,500' and 32F and 0' and 95 F on the same day.
As far as fuel supply, I had earlier tried a stock type tank and frame rail mounted high pressure pump. That was a no go. The pump was noisy and worse than that failed twice. High pressure pumps do not like to suck. I went to an in tank pump. In tank pump or remote sump with low pressure pump feeding the sump and sump feeding the high pressure pump is the way to go.
There are a number of options for in tank pumps including a modified OE style tank. Remote sumps can be purchased or homemade. If you go EFI I would strongly recommend one of these options.
Re: EFI or Carb? [Re: UCUDANT] #1940763
10/29/15 12:18 AM
10/29/15 12:18 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: EZ EFI or Carb? [Re: UCUDANT] #1940774
10/29/15 12:31 AM
10/29/15 12:31 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Installed a FAST EZ 2.0 on the 512 in my 69 Bee early last spring. So far 3,300 trouble free miles and loving it! My recommendation go for it.
Re: EZ EFI or Carb? [Re: Dabee] #1940783
10/29/15 12:44 AM
10/29/15 12:44 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Im looking at my in tank pump options... can anyone help?
http://www.summitracing.com/parts/aei-18688
Re: EZ EFI or Carb? [Re: UCUDANT] #1940800
10/29/15 01:40 AM
10/29/15 01:40 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
For the same price you can do a Spectra Tank with a Warbro pump that would look stock. Have you replaced your tank? I am in the process of replacing mine but used a Tank, Inc with a Warbro in tank pump.
http://www.amazon.com/Spectra-Premium-CR...keywords=cr8cfi
The seller at $407 is out of stock however.
http://www.tanksinc.com/index.cfm/page/p...prod/prd477.htm
Not a package deal but a la cart so you can size the Warbro for what you need
Craig
Re: EZ EFI or Carb? [Re: UCUDANT] #1940846
10/29/15 03:42 AM
10/29/15 03:42 AM
Zombieland
Car Nut Online laugh2
Zombieland
This would look/sound awesome on a 340.
Re: EZ EFI or Carb? [Re: denfireguy] #1940878
10/29/15 08:50 AM
10/29/15 08:50 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Craig
Thanks, I just spotted an ad for tanks inc in Mopar mag. I think I'll look into them today.
Re: EZ EFI or Carb? [Re: UCUDANT] #1941046
10/29/15 03:00 PM
10/29/15 03:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you don't mind the look, something like this feeding right into an in-line EFI pump would do the trick on the cheap.
http://www.summitracing.com/int/parts/cee-4041
Or you can buy a new stock tank for 150 bucks, cut a hole in the top and install a sump and your own provisions for a universal in-tank pump.
http://www.summitracing.com/int/parts/aei-11142
Or make or buy something like this for a stock tank. Looks like the install would be pretty easy.
http://www.summitracing.com/int/parts/tnk-pa-6
Re: EZ EFI or Carb? [Re: UCUDANT] #1941111
10/29/15 05:07 PM
10/29/15 05:07 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I installed the Phantom 340 kit in my Super Bee's tank this past spring.
The kit is high-quality and well thought out, but if you do it like they say (just drill a big hole in the tank), the kit will obviously just hit the trunk floor at the highest spot. I ended up spacing my tank down from the trunk using some thick rubber mat, but I'm not completely happy with it like that. The ideal way to do it would be to cut and weld a section of the tank to be lower and then install the kit into that section, but that was more effort than I wanted to do.
If I had to do it again (and if it had been available at the time), the Tanks-inc factory style tank is absolutely the way I would do it.
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: EZ EFI or Carb? [Re: UCUDANT] #1941164
10/29/15 06:36 PM
10/29/15 06:36 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
DO NOT DO EFI!!!
If you do it, then I will want to do it.
Re: EZ EFI or Carb? [Re: Car Nut] #1941197
10/29/15 07:20 PM
10/29/15 07:20 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
6-pack FI...exactly what I want to do to mine!!!
When you work on Spaceships for a living, how bad can a workday be?
Re: EZ EFI or Carb? [Re: UCUDANT] #1941200
10/29/15 07:25 PM
10/29/15 07:25 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Well the six packs are sitting right here. Almost ready to go.
Here's a link to one on the dyno.
https://www.youtube.com/watch?v=7ITny7eKRV4
Re: EZ EFI or Carb? [Re: Mopar_Rich] #1942975
11/01/15 02:08 PM
11/01/15 02:08 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My biased opinion...
Re: EZ EFI or Carb? [Re: Car Nut] #1942983
11/01/15 02:21 PM
11/01/15 02:21 PM
Kirkland, Washington
Pacnorthcuda Offline
I don't understand. In what way would that set up SOUND different than a carb?
Re: EZ EFI or Carb? [Re: Pacnorthcuda] #1943158
11/01/15 06:59 PM
11/01/15 06:59 PM
Zombieland
Zombieland
Bragging rights! If I say I had a six pack efi on my car, doesn't that SOUND better than I have 2 barrel CARB?
Re: EZ EFI or Carb? [Re: UCUDANT] #1950311
11/13/15 01:33 AM
11/13/15 01:33 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
UPDATE: while adjusting to ensure anequate idle vacuum I saw a difference in my Autometer, and shop gauge, I'll figure that out later....
A car I was eyeballing a state away is now suddenly within reach so this is upgrade is on hold. If I get that car, I'll sell a spare "driver" I have stashed and the parts for it, restocking some car cash. Purchase is a week out
Re: EZ EFI or Carb? [Re: UCUDANT] #1951074
11/14/15 02:41 PM
11/14/15 02:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d get a bigger carb and get it properly tuned/modified.......WAY cheaper and more dependable when set up correctly.......
Re: EZ EFI or Carb? [Re: UCUDANT] #1951254
11/14/15 10:05 PM
11/14/15 10:05 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Glad to hear that, sad to hear that. I was hoping to learn from your experience.
Have my injection tank wired but not plumbed. Gauge works...at least on empty. Still getting the return from the pressure regulator routed and connected. Old tank is is gone and disposed of. Could not get the sender out of it due to corrosion. Going to work some more on it tomorrow, looks like that last decent day for a while. Snow coming on Monday.
Craig
Re: EZ EFI or Carb? [Re: UCUDANT] #1951982
11/15/15 11:09 PM
11/15/15 11:09 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Why not try these guys? I've talked to the owner and have ridden in many cars that have autocrossed with them. They're pretty affordable and they're handheld system is great!
http://fitechefi.com/
https://www.youtube.com/watch?v=SsscxiUga5Y
