Page 1 of 3 1 2 3
Small block guys Timing Chain tensioner !!??? #1939873
10/27/15 09:05 PM
10/27/15 09:05 PM
CA.
RAY1969CARS Offline OP
CA.
Drag racer !!! Are you using them on your fresh builds?
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939875
10/27/15 09:11 PM
10/27/15 09:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Not me.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939876
10/27/15 09:11 PM
10/27/15 09:11 PM
Az
Crizila Offline
Crizila  Offline
Az
Some after market double roller chains will chew up the phenolic part of that adjuster. I used to use them, but don't anymore for that reason.
Fastest 300
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939879
10/27/15 09:18 PM
10/27/15 09:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I do. Haven't had any issue with aftermarket chains. 2 motors currently. One hydraulic roller 224/.560, one solid 240/.570. Both been together for over 10 years.
Doug
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939881
10/27/15 09:19 PM
10/27/15 09:19 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Go with the Milidon gear drive and never worry about sloppy chains. Much more stable and bulletproof.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small block guys Timing Chain tensioner !!??? [Re: B3422W5] #1939886
10/27/15 09:24 PM
10/27/15 09:24 PM
Washington
madscientist Offline
Washington
As simple as it may seem, this is 100% correct. 1 mile or 100k, you cam timing will be exactly the same.
I'm still waiting for actual PROOF that gear drives take HP or cause harmonics. I'm sure I'll be waiting til way past my death day.
The above only speaks to fixed idler 3 gear drives, or 2 gear drives (which require a reverse rotation cam). Not those crappy 4 gear things.
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939894
10/27/15 09:29 PM
10/27/15 09:29 PM
Az
Crizila Offline
Crizila  Offline
Az
My shat never lasts long enough for the chain to get sloppy.
Fastest 300
Re: Small block guys Timing Chain tensioner !!??? [Re: Crizila] #1939902
10/27/15 09:37 PM
10/27/15 09:37 PM
Washington
Washington
Sometimes you just can't argue with reality.
Good one.
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1939982
10/27/15 11:23 PM
10/27/15 11:23 PM
NC
barracuda man Offline
NC
I don't.I like the pro gear set.I do eye the milodon gear drive and the jessel belt drive.Just hate to drop that much coin. yellow
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940043
10/28/15 12:43 AM
10/28/15 12:43 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I saw a magazine test where they tested a gear drive, belt drive and chain drive and none made any more or less power than the others maybe someone else remembers the article, I think it was a chevy test engine. Maybe after 100,000 miles a chain may retard the cam but not any race engines short life span. If the chain is worn enough to need a tensioner than perhaps it is really time for replacement.
Re: Small block guys Timing Chain tensioner !!??? [Re: HotRodDave] #1940052
10/28/15 12:58 AM
10/28/15 12:58 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i read that article some years back. i had the chain tensioner in last build for 8yrs no issues. its going back in the new build that is now under way.
Re: Small block guys Timing Chain tensioner !!??? [Re: mopar dave] #1940077
10/28/15 01:36 AM
10/28/15 01:36 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
tall deck = long = chain.. I have had great luck with them. and use them on all my builds that use a chain
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small block guys Timing Chain tensioner !!??? [Re: WHITEDART] #1940191
10/28/15 08:49 AM
10/28/15 08:49 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Might it be most effective/useful in a situation where rpms are constantly changing, like road race or circle track?
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940283
10/28/15 12:12 PM
10/28/15 12:12 PM
CJD AUTOMOTIVE Offline
Use it! If for nothing else but to dampen harmonics. Remember, this was the bandaid for the 3.9 non-countershaft V6. But being the 3.9 is essential a 5.2 with two cylinders lopped off, it fits and works. I believe it does offer more stable timing, and as JCC suggested, when on and off the power, really helps stabilize the chain backlash. It's cheap and works. Hell, even GM uses a tensioner on the LS motors!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Small block guys Timing Chain tensioner !!??? [Re: CJD AUTOMOTIVE] #1940323
10/28/15 01:32 PM
10/28/15 01:32 PM
PA.
"Little"John
"Little"John
PA.
Last time this was posted some real nightmare stories about their use came out. Come-on guys lets hear the other side of the story.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940336
10/28/15 01:45 PM
10/28/15 01:45 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I have one in my SB stroker that I had anti-friction coating applied to on the touch surfaces.
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940339
10/28/15 01:52 PM
10/28/15 01:52 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had one on my 408, after five years it barely showed any wear signs. I was going to reuse on my new build but there was no way it was going on.
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940342
10/28/15 01:53 PM
10/28/15 01:53 PM
AndyF Offline
AndyF  Offline
All depends on which chain you use. I tried using the tensioner with a performance chain and the chain chewed it up very quickly. I don't think I'd bother using the tensioner on anything other than a stock type rebuild.
Re: Small block guys Timing Chain tensioner !!??? [Re: HotRodDave] #1940376
10/28/15 02:48 PM
10/28/15 02:48 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
On a related note, the Cloyes tensioner is 1/2 price of the MP version.
I used once and after a few thousand miles I wanted to swap cams. Found the double roller chain and already worn away the "pad" on the tensioner thus I won't do it again.
Re: Small block guys Timing Chain tensioner !!??? [Re: RAY1969CARS] #1940460
10/28/15 04:01 PM
10/28/15 04:01 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have used them, and seen mixed results.
On my turbo car the last time I took it apart (with a good timing chain), it had really chewed up the tensioner so I took it off.
Sort of surprising since they were factory installed pieces.
My take is that I think the better/tighter the chain, the more likely it is to chew up the tensioner.
Page 1 of 3 1 2 3
