Re: Small block guys Timing Chain tensioner !!???
[Re: RAY1969CARS]
#1939876
10/27/15 09:11 PM
10/27/15 09:11 PM
Posts: 7,506 Az
Crizila
Az
Some after market double roller chains will chew up the phenolic part of that adjuster. I used to use them, but don't anymore for that reason.
Fastest 300
[Re: RAY1969CARS]
#1939881
10/27/15 09:19 PM
10/27/15 09:19 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Go with the Milidon gear drive and never worry about sloppy chains. Much more stable and bulletproof.
[Re: B3422W5]
#1939886
10/27/15 09:24 PM
10/27/15 09:24 PM
Posts: 4,457 Washington
madscientist
Washington
Go with the Milidon gear drive and never worry about sloppy chains. Much more stable and bulletproof. As simple as it may seem, this is 100% correct. 1 mile or 100k, you cam timing will be exactly the same. I'm still waiting for actual PROOF that gear drives take HP or cause harmonics. I'm sure I'll be waiting til way past my death day. The above only speaks to fixed idler 3 gear drives, or 2 gear drives (which require a reverse rotation cam). Not those crappy 4 gear things.
[Re: RAY1969CARS]
#1939894
10/27/15 09:29 PM
10/27/15 09:29 PM
Posts: 7,506 Az
Crizila
Az
My shat never lasts long enough for the chain to get sloppy.
Fastest 300
[Re: Crizila]
#1939902
10/27/15 09:37 PM
10/27/15 09:37 PM
madscientist
Washington
My shat never lasts long enough for the chain to get sloppy. Sometimes you just can't argue with reality. Good one.
[Re: RAY1969CARS]
#1940043
10/28/15 12:43 AM
10/28/15 12:43 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I saw a magazine test where they tested a gear drive, belt drive and chain drive and none made any more or less power than the others maybe someone else remembers the article, I think it was a chevy test engine. Maybe after 100,000 miles a chain may retard the cam but not any race engines short life span. If the chain is worn enough to need a tensioner than perhaps it is really time for replacement.
[Re: mopar dave]
#1940077
10/28/15 01:36 AM
10/28/15 01:36 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
tall deck = long = chain.. I have had great luck with them. and use them on all my builds that use a chain
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1940191
10/28/15 08:49 AM
10/28/15 08:49 AM
Posts: 22,697 Bitopia
jcc
Bitopia
Might it be most effective/useful in a situation where rpms are constantly changing, like road race or circle track?
[Re: RAY1969CARS]
#1940283
10/28/15 12:12 PM
10/28/15 12:12 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Use it! If for nothing else but to dampen harmonics. Remember, this was the bandaid for the 3.9 non-countershaft V6. But being the 3.9 is essential a 5.2 with two cylinders lopped off, it fits and works. I believe it does offer more stable timing, and as JCC suggested, when on and off the power, really helps stabilize the chain backlash. It's cheap and works. Hell, even GM uses a tensioner on the LS motors!
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1940323
10/28/15 01:32 PM
10/28/15 01:32 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Last time this was posted some real nightmare stories about their use came out. Come-on guys lets hear the other side of the story.
