Anyone here running MT Pro Bracket Radials ? #1939087
10/26/15 06:49 PM
10/26/15 06:49 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Anyone here running these ?
Specifically 28x9R15 or 28x10.5R15
I need some new tyres and the Hoosier radial I run is out of stock
I only have 8 or 8 1/2" rear rims so it would seem the 28x9 is my only choice in the MT
Will the 28x9 be enough for my Satellite ?
I do not want to buy and find a poor result as they are $364.00 each here
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939138
10/26/15 07:58 PM
10/26/15 07:58 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I would like to know also.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939295
10/26/15 10:57 PM
10/26/15 10:57 PM
georgia
intenseneon Offline
intenseneon  Offline
georgia
Im running the 28x9x15 radials, no et or speed difference from the m/t bias ply of the same size on my small block dart. 7.20 1/8 mile car
69 Dart
Re: Anyone here running MT Pro Bracket Radials ? [Re: intenseneon] #1939319
10/26/15 11:14 PM
10/26/15 11:14 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
how do you find traction ? what weight ?
thanks
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939458
10/27/15 03:43 AM
10/27/15 03:43 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Bump. Anybody else? I am also looking 29.5x10.5. My car is 3900# ladder bar with 850-900HP I have always run bias slicks.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939507
10/27/15 10:23 AM
10/27/15 10:23 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
There is a guy running some done here with a transbrake used Nova that runs 6.40's. I've asked him about them and he loves them so far. Needs very little burnout and is more forgiving than the tradition radial. Lasts longer too.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Anyone here running MT Pro Bracket Radials ? [Re: Jacob Pitt] #1939541
10/27/15 11:04 AM
10/27/15 11:04 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I run them on my radial/ outlaw 275 car. Been 1.12 60' and lots of 1.13- 1.15. Some guys have been alot faster than that on them. They are easier to make work than a real drag radial but are by no means a slick. Still got to have a good shock and car set up. Have about 50 passes on them in the 4 sec zone still working great so imagine they would be long lasting on a bracket car.
One day I will have something cool here.
Re: Anyone here running MT Pro Bracket Radials ? [Re: sdaurity] #1939653
10/27/15 01:48 PM
10/27/15 01:48 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Are you sure you're not referencing of the "275 ET Street Radial Pro"? The OP is referencing the new "Pro-Bracket Radial", which is a true Radial construction Drag Slick, and is probably not legal for a an "outlaw 275" class(??).
http://www.mickeythompsontires.com/strip.php?item=BracketRadial
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939679
10/27/15 02:41 PM
10/27/15 02:41 PM
Renton Washington
Triple Threat Offline
Renton Washington
They are legal in most of the heads up classes. ET Street Radial, Pro Bracket Radial and the Pro drag radial.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939803
10/27/15 06:48 PM
10/27/15 06:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The Pro Bracket Radial is allowed in many classes that radials and slicks are both allowed.........So SD knows what tire he has.
They are NOTHING like a bias slick, but are more forgiving than true drag radials. You can't just toss them on and expect to treat them like a slick, or hit them like a slick.............But they are a bad azz tire. Many have had them on Outlaw Radial cars at recent races and I know Jeff Sitton went a .998 60ft on them at SGMP
These are NOT the same tire construction as the ET Drag Radial slick
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939806
10/27/15 06:57 PM
10/27/15 06:57 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I've just fitted them, first run on sun spun bad 1.77 with 20 psi, 2nd run tried 18psi went 1.40. Conditions weren't great, track was cold later when the sun went in.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939807
10/27/15 07:00 PM
10/27/15 07:00 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys .
talked to MT this morning , you can use the 28x10.5 on a narrower rim without too much disadvantage . Also talked to Centreline about custom backspace on their wheel I run , that is doable at no extra charge .
I am leery of running the 9" tyre , especially with a bigger motor under way .
I have only ever run radials , ET street radial , Radial Pro 275 ( poor result) and the last couple of years the Hoosier 275 radial slick with good success .
I also tried a Hoosier 9x30(29.9 tall) but the car wouldn't pull the last 100' or so , only 4.1 gear
the possible extra life would be a bonus
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: deaks] #1939810
10/27/15 07:01 PM
10/27/15 07:01 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Deaks ,
I have found with my Satellite 18-19psi is best . With all brands
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1939832
10/27/15 07:52 PM
10/27/15 07:52 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I have the 28/9 on my car but this is a fresh build and a low horsepower car so I can't really give you an opinion.
I hook and so far Ive had a 1.69 60' but again it's just a 12 second car that's only been to the track two times this year
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1940318
10/28/15 01:19 PM
10/28/15 01:19 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Got a set of the 28x9 PBR mounted on 15x7 wheels.
3.54 gear
3,950 Coronet
Autozone gas shocks, front rear & sway bars
*****also, I had to lower the front suspension 3/8", I suspect that hitting them too hard, too soon without quality shocks will also cause some spinning............if I had a quality double adjustable shock on the corners I think I could have left the ride height alone****
Lowest 60 foot so far is 1.63
Bracket race the car... had 3 or 4 runs that had a 330 time of 4.71......bunch of 1.64 and one 1.65 sixty
They do need enough of a burnout to see smoke coming from the tires. However, excessive burnout is no where necessary! Six seconds max. Engine RPM in the box above 4,000
Leave @ idle
16 pounds would spin a touch...sidewall wrinkle
17.5 pounds spin almost gone...less wrinkle
18 pounds no spin...virtually no wrinkle
If I recall:
7.30, 7.31, 7.32, 7.31 on one day
11.67, 11.67, 11.68, 11.67 on another day
If the dummy behind the wheel was a seasoned bracket racer the car would be in more semi's.
Re: Anyone here running MT Pro Bracket Radials ? [Re: StealthWedge67] #1940329
10/28/15 01:39 PM
10/28/15 01:39 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Yeah that is the tire. For me they work better on a descent track. I keep a set of 3754x in the trailer for when we are at an awesome surface cause they are faster than bracket radials. I keep a set of 28x10.5 stiff walls too for a junk track.
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1940564
10/28/15 06:49 PM
10/28/15 06:49 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
ok ,
got some 10.5's arriving . Will be testing on Saturday , will use the 8 1/2" rims if possible
thanks Silver67 for your input
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1944547
11/03/15 08:37 PM
11/03/15 08:37 PM
georgia
intenseneon Offline
intenseneon  Offline
georgia
thanks
Tex
69 dart 3000lbs car. I have the calvert suspension all around run 17-18 psi, works good i dont have issue with spin i try to do a smaller burnout. I have 140 passes on them and they are working good last race out sixty foots were 1.613 to .604 the 604 being the last pass on a cooler dark track.
69 Dart
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1944557
11/03/15 08:56 PM
11/03/15 08:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks
I tested last Saturday . Sixties were 1.52-1.55 .No different to the Hoosier 275 , very happy . I was only doing a light burnout , I think it needs a bit more . No real pickup on the tyre on return road .
Definitely more stable with air pressure , picked up less pressure gain after driving to staging lanes and after a pass .
I used a 8 1/2" rim which gave a 9-9 1/2" contact patch . Still showed marking on the edge . I have ordered 10" rims .
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1947456
11/08/15 12:10 PM
11/08/15 12:10 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have been thinking about this tire, but not being "street legal", I am wary about driving it around.
I currently run the 315 ET DR on a 12" rim. And the rim size would be my concern on the 10.5 PRO.
Here are the comparisons:
Tire..............Style......Compound..Height..Section..Tread..Weight
315x60x15..ET DR.....R2..............30........12.9......11.9....39
29.5x10.5....PRO.......X5...............30........12.7......10.2....33
Thoughts?
