Re: 499 RB pump-gas cam suggestions 3.23 gears.
[Re: ahy]
#1939950
10/27/15 10:28 PM
10/27/15 10:28 PM
Posts: 6,572 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
The "new" 528 has 112 LSA for better manners I guess. I believe the "old " 528 was tighter - something like 108 degrees.
Mike at Muscle Motors spec'ed my cam. It is a fast rate MM lobe, 243 duration, .55" lift, 108 LSA. Timing very similar to the "old" 528 just a bit more lift. 13" vacuum. I consider it choppy but I guess that is subjective. If you want it choppy, better to go the custom cam route with tighter LSA. Also, based on Mike's experience, 108 LSA is best for acceleration with this type of combo. I just know it works well... loads of mid range torque and will hang in to and beyond 6000 RPM if needed... eg. to get that last little bit of straight away before the turn without pulling 5'th gear. Actually it's the MP509 that had the LSA widened from 108. The 528 was always wide. 114? Just looked it up. 112 Kevin
[Re: SomeCarGuy]
#1939956
10/27/15 10:40 PM
10/27/15 10:40 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
x2. The fastest way to being disappointed driving the car is buying a cam for the sound.
[Re: moper]
#1940104
10/28/15 02:45 AM
10/28/15 02:45 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
x2. The fastest way to being disappointed driving the car is buying a cam for the sound. X3 I agree as I have a custom grind from Dwayne and it works just as I asked for. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Ron
[Re: Twostick]
#1940619
10/28/15 08:21 PM
10/28/15 08:21 PM
Posts: 7,664 IN
ahy
IN
Actually it's the MP509 that had the LSA widened from 108. The 528 was always wide. 114? Just looked it up. 112 Kevin Thanks for the correction... agree as many have said, the the 528 with 112 may not be ideal for the OP's goals and a custom cam would be worth it.
[Re: SILVER67]
#1942546
10/31/15 10:22 PM
10/31/15 10:22 PM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
Street driven just under 5,000 miles with:
Weekly Bracket race as well.
505 BBM Pump Gas Power Brakes
Comp Cam custom flat tappet by Nick @ Compuflo
1.5 rocker .585 I, .600 E 260@50 I , 268@50 E
109 CL, 104 installed
3.23 gears, 9-1/2 Dynamic
With the 3.23 it bested 11.57, and couple of 11.59's, otherwise in the heat was an 11.60's car...at a hair over 116 MPH.
Father has same Comp Cam lobe family flat tappet in his 440 pump gas Roadrunner. He's got 3.23 as well.
He's bested 11.85 @ 112 otherwise it does 11.90's to 12.00's If he'd drive it more that would be dandy. It idles like a pussycat.
Mike
NICE! RIP: Nick Wilson (CompuFlow). 260/268 @.050" flat tappet on a 109LSA makes me reconsider the 255 @.050" street roller on a 110LSA! I won't even have power brakes, I just wanted the vacuum as an indication of idle quality and throttle response. Thanks for the reply!!
