Poor man line lock... #1938275
10/25/15 01:08 PM
10/25/15 01:08 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I always wanted to have a line lock on my original 1967 Charger, but I don't like the idea to modify the originality of the car.
I checked on Ebay for a discrete valve...
I found a Whitey B-43F4 Brass Ball Valve - 1/4in - 0.9 CV - 40 Series for $15.00 + 4.95 shipping and installation 2 hours.
Works Great up
Re: Poor man line lock... [Re: STROKIE] #1938290
10/25/15 01:40 PM
10/25/15 01:40 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I hope ya never unknowingly bump it closed vacuuming, or reaching around under the seat, or someone else admiring your car ect.
Could be a "surprise"! no front brakes.
Re: Poor man line lock... [Re: dthemi] #1938298
10/25/15 01:53 PM
10/25/15 01:53 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
That looks like it is set up to block pressure to the rear brakes. That Is how I set up all the ones I do, works great on automatic cars.
The only Carbs I care about are under the hood!
Re: Poor man line lock... [Re: Azzkikrcuda] #1938304
10/25/15 02:09 PM
10/25/15 02:09 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Yeah, looks rr brk interrupt, a good way to do brake torque burnouts.
Re: Poor man line lock... [Re: STROKIE] #1938338
10/25/15 02:59 PM
10/25/15 02:59 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
If you drag race the car you might want to read NHRA rulebook gen reg section 3.1 "All line-locs
(electric or hydraulic) must be self-returning to normal brake operating mode". I am not trying to be a jerk just wanted you to know
"Just a Bracket car dressed up like a streetcar"
Re: Poor man line lock... [Re: Just-a-dart] #1938359
10/25/15 04:02 PM
10/25/15 04:02 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
It's not a drag car, just a occasional strip... drive
https://www.youtube.com/watch?v=tt-x-_3jjmE
Re: Poor man line lock... [Re: STROKIE] #1938451
10/25/15 07:22 PM
10/25/15 07:22 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Works Great up
what a joke👎
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Poor man line lock... [Re: STROKIE] #1938517
10/25/15 08:51 PM
10/25/15 08:51 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It is people like you who insure that I will never be able to say " I've seen it all ".
So thanks........I think.
Re: Poor man line lock... [Re: STROKIE] #1938588
10/25/15 10:23 PM
10/25/15 10:23 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I could think of 20 different ways to hide a line lock... That's not one of them, seems dangerous...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Poor man line lock... [Re: STROKIE] #1938699
10/26/15 01:04 AM
10/26/15 01:04 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No more dangerous than a misadjusted, as in "cut off" adjustable proportioning valve. They will both shut the rear brakes off................BUT, you can actually use an electric one right where you have that valve. Flip the switch BEFORE you push the brakes, solenoid closes.......viola, no rear brakes
Re: Poor man line lock... [Re: STROKIE] #1938707
10/26/15 01:09 AM
10/26/15 01:09 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Guys quit hating, friend of mine has a 65 Belvedere been a race car sense 72 has a ball valve. Set up and has never been hit/turned on by accident works fine and can use as a temp parking brake while its on his trailer. Lot of libs showing there colors.
Make shur you don't have that full race cam and a spool on the street either.
Re: Poor man line lock... [Re: STROKIE] #1938761
10/26/15 03:14 AM
10/26/15 03:14 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
What I don't get it is you mention originality and then you cut a hole in the floor and modified the brake line.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Poor man line lock... [Re: STROKIE] #1938885
10/26/15 01:01 PM
10/26/15 01:01 PM
Az
Crizila Offline
Crizila  Offline
Az
Understand, but still not a good idea from a safety standpoint. Weather you are cutting out the front or rear brakes, it should be done with a momentary switch operating a solenoid and the system should be energized with a SPST toggle switch ( with an arming light if possible ). A little more work, but you could hide most of it easily enough. beer
Fastest 300
Re: Poor man line lock... [Re: Crizila] #1938913
10/26/15 01:51 PM
10/26/15 01:51 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Thanks for your comments, and likes the idea of momentary switch operating a solenoid and the system energized with a SPST toggle switch... up
Re: Poor man line lock... [Re: STROKIE] #1938953
10/26/15 03:11 PM
10/26/15 03:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Never use a toggle swith. That's as dangerous as anything. A push button is the only way to go.
Re: Poor man line lock... [Re: STROKIE] #1938962
10/26/15 03:20 PM
10/26/15 03:20 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
So what kind of pressure is that valve rated for?
Kevin
Re: Poor man line lock... [Re: Twostick] #1939033
10/26/15 05:22 PM
10/26/15 05:22 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Kevin
3000 PSIG @ 100°F /206 BAR @ 37°C
with a max temperature rating of
150 F 3000 PSIG /65 C 206 BAR
according to the data sheet
Re: Poor man line lock... [Re: STROKIE] #1939072
10/26/15 06:30 PM
10/26/15 06:30 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
ball valve are used in just about every oval race car that allows them to be used for RF brake shut off and or right side brakes shut off, im about to install one on mine for line lock, simple and ez, for any body whos worried a saftey or break away wire can be used to lock the valve in the open position.
Re: Poor man line lock... [Re: STROKIE] #1939094
10/26/15 07:09 PM
10/26/15 07:09 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I used to drive a tow truck that had a valve like that to lock all four wheels during winch and recovery work. You should have no problem with it, good luck!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Poor man line lock... [Re: STROKIE] #1939096
10/26/15 07:13 PM
10/26/15 07:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Something like that might make a good anti-theft device.
