Poor man line lock...
#1938275
10/25/15 01:08 PM
10/25/15 01:08 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
I always wanted to have a line lock on my original 1967 Charger, but I don't like the idea to modify the originality of the car. I checked on Ebay for a discrete valve... I found a Whitey B-43F4 Brass Ball Valve - 1/4in - 0.9 CV - 40 Series for $15.00 + 4.95 shipping and installation 2 hours. Works Great
Re: Poor man line lock...
[Re: dthemi]
#1938298
10/25/15 01:53 PM
10/25/15 01:53 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
That looks like it is set up to block pressure to the rear brakes. That Is how I set up all the ones I do, works great on automatic cars.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#1938304
10/25/15 02:09 PM
10/25/15 02:09 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Yeah, looks rr brk interrupt, a good way to do brake torque burnouts.
[Re: STROKIE]
#1938338
10/25/15 02:59 PM
10/25/15 02:59 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If you drag race the car you might want to read NHRA rulebook gen reg section 3.1 "All line-locs (electric or hydraulic) must be self-returning to normal brake operating mode". I am not trying to be a jerk just wanted you to know
"Just a Bracket car dressed up like a streetcar"
[Re: STROKIE]
#1938451
10/25/15 07:22 PM
10/25/15 07:22 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I always wanted to have a line lock on my original 1967 Charger, but I don't like the idea to modify the originality of the car. I checked on Ebay for a discrete valve... I found a Whitey B-43F4 Brass Ball Valve - 1/4in - 0.9 CV - 40 Series for $15.00 + 4.95 shipping and installation 2 hours. Works Great what a joke👎
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: STROKIE]
#1938699
10/26/15 01:04 AM
10/26/15 01:04 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
No more dangerous than a misadjusted, as in "cut off" adjustable proportioning valve. They will both shut the rear brakes off................BUT, you can actually use an electric one right where you have that valve. Flip the switch BEFORE you push the brakes, solenoid closes.......viola, no rear brakes
[Re: STROKIE]
#1938707
10/26/15 01:09 AM
10/26/15 01:09 AM
Posts: 791 Bama
Randy..
Bama
Guys quit hating, friend of mine has a 65 Belvedere been a race car sense 72 has a ball valve. Set up and has never been hit/turned on by accident works fine and can use as a temp parking brake while its on his trailer. Lot of libs showing there colors. Make shur you don't have that full race cam and a spool on the street either.
[Re: STROKIE]
#1938761
10/26/15 03:14 AM
10/26/15 03:14 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
What I don't get it is you mention originality and then you cut a hole in the floor and modified the brake line.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: STROKIE]
#1938885
10/26/15 01:01 PM
10/26/15 01:01 PM
Posts: 7,506 Az
Crizila
Az
Understand, but still not a good idea from a safety standpoint. Weather you are cutting out the front or rear brakes, it should be done with a momentary switch operating a solenoid and the system should be energized with a SPST toggle switch ( with an arming light if possible ). A little more work, but you could hide most of it easily enough.
Fastest 300
[Re: Twostick]
#1939033
10/26/15 05:22 PM
10/26/15 05:22 PM
Posts: 760 Canada
CTD5.9
Canada
So what kind of pressure is that valve rated for?
Kevin 3000 PSIG @ 100°F /206 BAR @ 37°C with a max temperature rating of 150 F 3000 PSIG /65 C 206 BAR according to the data sheet
[Re: STROKIE]
#1939094
10/26/15 07:09 PM
10/26/15 07:09 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I used to drive a tow truck that had a valve like that to lock all four wheels during winch and recovery work. You should have no problem with it, good luck!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
