Page 1 of 3 1 2 3
Alternator upgrade? #1937764
10/24/15 02:50 PM
10/24/15 02:50 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I'd like to upgrade the alternator on my street/strip small block 69 Dart. Currently I'm running a square back two field and would like to up grade this winter while I'm finishing up my new engine build. the car has a Magnafuel 275 pump and a Digital 6 ignition, no electric fan or water pump but would like to have some extra capacity if I want to upgrade later.
What's a good simple alternator up grade?
Thanks.
Re: Alternator upgrade? [Re: justinp61] #1937768
10/24/15 02:59 PM
10/24/15 02:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running the 70 amp Denso from a mid 80`s Toyota 4-runner.......
Re: Alternator upgrade? [Re: justinp61] #1937781
10/24/15 03:23 PM
10/24/15 03:23 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
East coast auto electric
Re: Alternator upgrade? [Re: justinp61] #1937785
10/24/15 03:35 PM
10/24/15 03:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Anyone use one of these? I got the web link from the JOC (Jensen Owners Club)
http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
Re: Alternator upgrade? [Re: justinp61] #1937787
10/24/15 03:38 PM
10/24/15 03:38 PM
AndyF Offline
AndyF  Offline
Use the Denso mounting kit. You can either buy a new Denso alternator or find one in a wrecking yard or alternator place.
Re: Alternator upgrade? [Re: justinp61] #1937789
10/24/15 03:48 PM
10/24/15 03:48 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
i third the denso. great alternator, easy wiring and great low idle power, no dimming of headlights
Re: Alternator upgrade? [Re: justinp61] #1937793
10/24/15 03:57 PM
10/24/15 03:57 PM
W. Kentucky
W. Kentucky
Thanks guys! Anyone have a p/n for the Denso?
Re: Alternator upgrade? [Re: AndyF] #1937801
10/24/15 04:16 PM
10/24/15 04:16 PM
W. Kentucky
W. Kentucky
Andy is your site down?
Re: Alternator upgrade? [Re: justinp61] #1937814
10/24/15 05:20 PM
10/24/15 05:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am using a GM CS130 alternator. It is one of the best things I have ever done to my car no questions. It charges at 14.5-14.7 with a 5" crank pulley at idle. I have electric fans(2) WP, and Fuel Pump.
I am running it to a continuous duty relay so my kill switch will work and it feeds into my power distribution point. I have been real happy with how it has all worked.
68 Barracuda Formula S 340
Re: Alternator upgrade? [Re: 451Mopar] #1937815
10/24/15 05:21 PM
10/24/15 05:21 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
HOLY COW!!! I could run all the accessories on any Mopar that I have and do some welding on the side with one of those...but, I can't see it for a once a month bracket beast. I will start haunting the local yards for a Denso.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Alternator upgrade? [Re: justinp61] #1937828
10/24/15 05:43 PM
10/24/15 05:43 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my street/strip 'cuda uses a Tuff Stuff alternator. looks factory, mounts on the same brackets & connects to the factory regulator & pumps out 100 amps so it charges up quickly. no complaints from me.
Re: Alternator upgrade? [Re: justinp61] #1937829
10/24/15 05:44 PM
10/24/15 05:44 PM
AndyF Offline
AndyF  Offline
I don't think so. I can get to it just fine.
www.arengineering.com works for me.
Re: Alternator upgrade? [Re: justinp61] #1937874
10/24/15 07:01 PM
10/24/15 07:01 PM
W. Kentucky
W. Kentucky
I can't open it with IE 10, MS Edge, Google Chrome or my I phone.
Re: Alternator upgrade? [Re: justinp61] #1937897
10/24/15 07:30 PM
10/24/15 07:30 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Opens up just fine for me. OS X with Safari
Damon
Re: Alternator upgrade? [Re: justinp61] #1937901
10/24/15 07:36 PM
10/24/15 07:36 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i second the tuff stuff, been on for a few years now and looks factory (except mine is black)
Re: Alternator upgrade? [Re: justinp61] #1937902
10/24/15 07:38 PM
10/24/15 07:38 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Does the Denso have a built in regulator ?
Re: Alternator upgrade? [Re: justinp61] #1937907
10/24/15 07:51 PM
10/24/15 07:51 PM
W. Kentucky
W. Kentucky
This is what I get with Chrome. I even turned my firewall off, still won't open. shruggy
This webpage is not available
DNS_PROBE_FINISHED_NXDOMAIN
ReloadHide details
The server at www.arengineering.com can't be found, because the DNS lookup failed. DNS is the network service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network. It can also be caused by an unresponsive DNS server or a firewall preventing Google Chrome from accessing the network.
Re: Alternator upgrade? [Re: justinp61] #1937930
10/24/15 08:28 PM
10/24/15 08:28 PM
AndyF Offline
AndyF  Offline
works fine for me from different computers as well as on my phone. You might have something cached in your router that is causing the problem.
Re: Alternator upgrade? [Re: justinp61] #1937937
10/24/15 08:39 PM
10/24/15 08:39 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i run the denso kit, its a great kit
Re: Alternator upgrade? [Re: AndyF] #1937939
10/24/15 08:42 PM
10/24/15 08:42 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Works fine for me Win 7 on Chrome with Ghostery and Ad Block.
Page 1 of 3 1 2 3
