Most stable valve train???
#1935502
10/20/15 12:32 PM
10/20/15 12:32 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What is the most stable springs, shims/spacers or collars on valve train for a 426 style hemi??? I looked on Stage V website at some pictures and the show collars. What's your thoughts on advantages and disadvantages? This is for a 582" all aluminum Hemi .650 lift, 280 duration, 80% track- 20% street.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Most stable valve train???
[Re: 65 Hemi]
#1935539
10/20/15 02:02 PM
10/20/15 02:02 PM
Posts: 2,690 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
At that lift the stock configuration stuff is good enough. Stage V rockers are the prettiest and I use Keith Black stands, shafts, plugs and springs.
2011 Drag Pak Challenger
[Re: rickseeman]
#1935563
10/20/15 02:33 PM
10/20/15 02:33 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
At that lift the stock configuration stuff is good enough. Stage V rockers are the prettiest and I use Keith Black stands, shafts, plugs and springs. I have the KB stands and shafts, but I'm using the DLI roller rockers which aren't made anymore. I have the stock spring and shim setup, although most say the collars are better. My roller cam is only .672"/.651" lift though...no problems at all after nearly 10 years.
[Re: 65 Hemi]
#1935572
10/20/15 02:56 PM
10/20/15 02:56 PM
65 Hemi
San Diego CA
Thanks for the input. My concern is I bought this motor from a guy that bought it from an estate from a old KOS racer. It was built by a well know builder. The motor was over 10 years old but new(never run and never apart) so I took it apart for inspection and one of the Norris rockers roller tip was pushed off the side of the valve on the retainer. It may have been bump over during assembly. I'm sure glad I caught it. I have no problem buying the collars if it is a better route.
Doug
[Re: BradH]
#1935583
10/20/15 03:05 PM
10/20/15 03:05 PM
an8sec70cuda
Holy Mother of God, get rid of those archaic springs!!! The collar setup may be better, but why change now? I've been running mid 9s at almost 2 tons for 9+ years and just recently dipped into the 8s. I'm not seeing a reason to change anything. The springs obviously do their job on my setup. If there was gonna be a problem, I'm pretty sure I'd have seen it by now.
[Re: 65 Hemi]
#1935627
10/20/15 04:15 PM
10/20/15 04:15 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Buy the Stage V collars with the wave springs and set the clearances up to what they recommend. The Hemi motors really need a very good set of pushrods and valve spring to rev and live If you wanted to race it a lot I would say convert to the Jesel rockers or another brand as good as they are If street and occasional 7500 RPM blast use the good springs and pushrods with the rockers you've got
[Re: Cab_Burge]
#1935671
10/20/15 05:30 PM
10/20/15 05:30 PM
65 Hemi
San Diego CA
Buy the Stage V collars with the wave springs and set the clearances up to what they recommend. The Hemi motors really need a very good set of pushrods and valve spring to rev and live If you wanted to race it a lot I would say convert to the Jesel rockers or another brand as good as they are If street and occasional 7500 RPM blast use the good springs and pushrods with the rockers you've got I thought the Norris Stainless Steel rockers were good. Is that not the case?
Doug
[Re: 65 Hemi]
#1935678
10/20/15 05:40 PM
10/20/15 05:40 PM
rickseeman
Stuttgart, Arkansas
You have Indy heads with cast in stands. Not much there that you can change. You can put collars on if you want. I prefer not to.
[Re: 65 Hemi]
#1935686
10/20/15 05:59 PM
10/20/15 05:59 PM
an8sec70cuda
Norris rockers are better than stock, but that's about it.
[Re: an8sec70cuda]
#1935726
10/20/15 07:10 PM
10/20/15 07:10 PM
65 Hemi
San Diego CA
Norris rockers are better than stock, but that's about it. Ok, I will keep an eye on them and may switch them out after I get the car running. I just knew Bob Mazzolini use to push them 15 to 20 years ago.
Doug
[Re: 65 Hemi]
#1935744
10/20/15 07:31 PM
10/20/15 07:31 PM
Posts: 4,213 New York
polyspheric
New York
I see weight reduction has high priority with Norris?
An FEA analysis of those rockers would give me a coronary!
Boffin Emeritus
[Re: 65 Hemi]
#1935757
10/20/15 07:57 PM
10/20/15 07:57 PM
65 Hemi
San Diego CA
Man! I love the look of Stage V. I would want clear valve covers...
Doug
[Re: 65 Hemi]
#1935801
10/20/15 09:16 PM
10/20/15 09:16 PM
Posts: 12,326 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What is a good source for the wave washers? Mine already has collars and I would prefer to add those style washers.
Master, again and still
[Re: an8sec70cuda]
#1937262
10/23/15 01:29 PM
10/23/15 01:29 PM
BradH
Holy Mother of God, get rid of those archaic springs!!! The collar setup may be better, but why change now? It's just me... I can't stand half-a$$ed, budget-driven, band-aid engineering. Using a cheesy spring to try and keep a loaded rocker arm in position vs. a stable method that maintains the correct location on the shaft just strikes me as 1950s OEM technology. Carry on...
[Re: 65 Hemi]
#1937266
10/23/15 01:39 PM
10/23/15 01:39 PM
an8sec70cuda
It obviously works fine. Even in some pretty extreme situations...such as mine for the past 10 years. If mine hasn't experienced any issues w/ that setup yet, then I'm sure not going to change now.
