Most stable valve train??? #1935502
10/20/15 12:32 PM
10/20/15 12:32 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What is the most stable springs, shims/spacers or collars on valve train for a 426 style hemi??? I looked on Stage V website at some pictures and the show collars. What's your thoughts on advantages and disadvantages? This is for a 582" all aluminum Hemi .650 lift, 280 duration, 80% track- 20% street.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Most stable valve train??? [Re: 65 Hemi] #1935539
10/20/15 02:02 PM
10/20/15 02:02 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
At that lift the stock configuration stuff is good enough. Stage V rockers are the prettiest and I use Keith Black stands, shafts, plugs and springs.
2011 Drag Pak Challenger
Re: Most stable valve train??? [Re: rickseeman] #1935563
10/20/15 02:33 PM
10/20/15 02:33 PM
an8sec70cuda Offline
iagree I have the KB stands and shafts, but I'm using the DLI roller rockers which aren't made anymore.
I have the stock spring and shim setup, although most say the collars are better. My roller cam is only .672"/.651" lift though...no problems at all after nearly 10 years.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Most stable valve train??? [Re: an8sec70cuda] #1935569
10/20/15 02:52 PM
10/20/15 02:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Holy Mother of God, get rid of those archaic springs!!! cry
Re: Most stable valve train??? [Re: 65 Hemi] #1935572
10/20/15 02:56 PM
10/20/15 02:56 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for the input. My concern is I bought this motor from a guy that bought it from an estate from a old KOS racer. It was built by a well know builder. The motor was over 10 years old but new(never run and never apart) so I took it apart for inspection and one of the Norris rockers roller tip was pushed off the side of the valve on the retainer. It may have been bump over during assembly. I'm sure glad I caught it. I have no problem buying the collars if it is a better route.
Doug
MOPAR or NO CAR!!!
Re: Most stable valve train??? [Re: BradH] #1935583
10/20/15 03:05 PM
10/20/15 03:05 PM
The collar setup may be better, but why change now? I've been running mid 9s at almost 2 tons for 9+ years and just recently dipped into the 8s. I'm not seeing a reason to change anything. The springs obviously do their job on my setup. If there was gonna be a problem, I'm pretty sure I'd have seen it by now.
CHIP
Re: Most stable valve train??? [Re: 65 Hemi] #1935627
10/20/15 04:15 PM
10/20/15 04:15 PM
Buy the Stage V collars with the wave springs and set the clearances up to what they recommend. The Hemi motors really need a very good set of pushrods and valve spring to rev and live up If you wanted to race it a lot I would say convert to the Jesel rockers or another brand as good as they are scope If street and occasional 7500 RPM blast use the good springs and pushrods with the rockers you've got thumbs twocents
Re: Most stable valve train??? [Re: Cab_Burge] #1935671
10/20/15 05:30 PM
10/20/15 05:30 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I thought the Norris Stainless Steel rockers were good. Is that not the case?
Doug
MOPAR or NO CAR!!!
Re: Most stable valve train??? [Re: 65 Hemi] #1935678
10/20/15 05:40 PM
10/20/15 05:40 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You have Indy heads with cast in stands. Not much there that you can change. You can put collars on if you want. I prefer not to.
Re: Most stable valve train??? [Re: 65 Hemi] #1935686
10/20/15 05:59 PM
10/20/15 05:59 PM
Norris rockers are better than stock, but that's about it.
CHIP
Re: Most stable valve train??? [Re: an8sec70cuda] #1935726
10/20/15 07:10 PM
10/20/15 07:10 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Ok, I will keep an eye on them and may switch them out after I get the car running. I just knew Bob Mazzolini use to push them 15 to 20 years ago.
Doug
MOPAR or NO CAR!!!
Re: Most stable valve train??? [Re: 65 Hemi] #1935744
10/20/15 07:31 PM
10/20/15 07:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I see weight reduction has high priority with Norris?
An FEA analysis of those rockers would give me a coronary!
Boffin Emeritus
Re: Most stable valve train??? [Re: 65 Hemi] #1935754
10/20/15 07:49 PM
10/20/15 07:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Hard to beat Stage-V rockers with good heads and collars (if they are not installed too tight).
Re: Most stable valve train??? [Re: 65 Hemi] #1935757
10/20/15 07:57 PM
10/20/15 07:57 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Man! I love the look of Stage V. I would want clear valve covers...
Doug
MOPAR or NO CAR!!!
Re: Most stable valve train??? [Re: 65 Hemi] #1935801
10/20/15 09:16 PM
10/20/15 09:16 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What is a good source for the wave washers? Mine already has collars and I would prefer to add those style washers.
Master, again and still
Re: Most stable valve train??? [Re: 65 Hemi] #1935816
10/20/15 09:37 PM
10/20/15 09:37 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Re: Most stable valve train??? [Re: Mopar_Rich] #1937044
10/22/15 11:34 PM
10/22/15 11:34 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Rich will that Stage V setup as pictured fit under a stock black valve cover?
If you wouldn't mind could you PM me the cost of that setup. I will be building a 481 Edelbrock Vic jr head engine , using a flat tappet cam, yet to be determined.
Re: Most stable valve train??? [Re: DUSTER_340] #1937256
10/23/15 01:14 PM
10/23/15 01:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Send me an email (rich@fastmanefi.com) and tell me what you want. When you say "setup" what all do you mean? rockers, stands, everything? or just the collars we discussed?
Re: Most stable valve train??? [Re: an8sec70cuda] #1937262
10/23/15 01:29 PM
10/23/15 01:29 PM
BradH Offline
BradH  Offline
It's just me... I can't stand half-a$$ed, budget-driven, band-aid engineering.
Using a cheesy spring to try and keep a loaded rocker arm in position vs. a stable method that maintains the correct location on the shaft just strikes me as 1950s OEM technology.
Carry on...
Re: Most stable valve train??? [Re: 65 Hemi] #1937266
10/23/15 01:39 PM
10/23/15 01:39 PM
It obviously works fine. Even in some pretty extreme situations...such as mine for the past 10 years. If mine hasn't experienced any issues w/ that setup yet, then I'm sure not going to change now.
CHIP
