Wiring up an electric fuel pump..... #1936744
10/22/15 03:16 PM
10/22/15 03:16 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
.....like this.....can you use the MOPAR three prong one from the mid 80's instead of the GM one......I'm at least hoping that the MOPAR plug will fit the GM switch.
Moparlee
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1936832
10/22/15 05:16 PM
10/22/15 05:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Which "switch" are you talking about - or do you mean the "relay" ??
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1936850
10/22/15 05:43 PM
10/22/15 05:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The oil pressure switch, which shuts off the fuel pump if there is no oil pressure, unless in start.
Don't be the exception.
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1936856
10/22/15 05:56 PM
10/22/15 05:56 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Correct
Moparlee
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1936877
10/22/15 06:34 PM
10/22/15 06:34 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
AKA a Hobbs switch. I used a similar system on my old bracket car and it worked well. I only had one of the old Holley 110 GPH pumps and did not use a relay then. My new racer uses the Holley Black pump and I will be wiring in the relay this time.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1936879
10/22/15 06:44 PM
10/22/15 06:44 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Sweet
Moparlee
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1937026
10/22/15 11:07 PM
10/22/15 11:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mount the realy as close as possible to the pump. feed the relay with the proper gauge wire for that load scope Use the trugger wire from the ignition switch to activate the relay, not to feed the fuel pump tsk You may need to put a push to bypass, open, the ground wire from the Hobbs switch to allow the motor to start and build oil pressure before the Hobbs switch operates correctly scope thumbs IHTHs
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1937213
10/23/15 11:36 AM
10/23/15 11:36 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I really would like the relay under the hood, could I run a bigger wire from the relay to the pump?
I would rather not have the relay under the Ramcharger.....daily driver....I've had an extra blue pump laying around so I'm going to use it on this, but like I said I would rather not have the relay under the truck. All the instructions say to do it, but....man....I would rather not. In my Valiant I put in the trunk.
I went ahead and bought the GM switch....it would be nice to use the three prong switch that the mid 80's Dodge truck used, but that's the berries. I'm going to use that mopar plug for the GM switch.....thanks for everybody's feed back.
Moparlee
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1937284
10/23/15 02:15 PM
10/23/15 02:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Yes, you can mount the relay under the hood and run a large gauge wire to the pump, but then what is the point of using a relay?
The relay is in place to allow the use of a light trigger wire to engage the pump and that is assuming that you have mounted the battery close to the pump and only need a short length of heavy wire from the relay to make the connection between the battery, the pump and ground.
If you don't want to mount a relay, then use an electric pump with little amp draw like a cheap low pressure Carter that would not need a pressure regulator.
2008 Honda Element
Re: Wiring up an electric fuel pump..... [Re: Polarapete] #1937545
10/23/15 10:01 PM
10/23/15 10:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The point of using a relay is so that hte relay can safely and adequately handle the load and not alight duty switch. You'll note where the OEM's mount their relays? In the engine compartment, yes even the fuel pump relay. I'd rather not have a long, heavy gauge wire running the length of my car that is always hot and that's what you'll have if you mount hte relay by the pump.
Re: Wiring up an electric fuel pump..... [Re: Robbins] #1937715
10/24/15 12:46 PM
10/24/15 12:46 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Agreed....I'm thinking just cover the power wire coming from the relay really good feeding the relay off the breaker and that breaker being feed from a madd terminal that's feed off the alt.
Moparlee
