Re: 70 challenger front suspension upgrade?
[Re: sean1970]
#1936705
10/22/15 02:19 PM
10/22/15 02:19 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
As old school as it sounds, I would stick with a light torsion bar. There are a couple local cars around here that are deadly out of the hole, and they are light torsion bars, and tubular uppers and a good front shock.
Ideally, a nice tubular front with coil overs is a nice way to shed weight, and have good control over the front end, but as you mentioned, expensive.
For me, I will probably just end up cutting the front of my car off and putting mustang struts in the front. LOL
-Kenny
[Re: sean1970]
#1936943
10/22/15 08:26 PM
10/22/15 08:26 PM
Posts: 9,884 MI, usa
dvw
MI, usa
I want to upgrade the front suspension on my 70 challenger. What are you guys using that works well? I have looked around at k-members etc and the super expensive. Here is what I am thinking
disc brakes tubular a-arms coil overs k-member? Drag car? I've found that my 64 Belvedere works just fine with the stock K-member trimmed, good bushings, Heims in the outer tie rod position to set bump steer to near zero, and Afco double adjustable shocks. Car has been 9.02@151. Front end stays square, drives fine. Doug
[Re: sean1970]
#1937555
10/23/15 10:33 PM
10/23/15 10:33 PM
Posts: 1,837 tulsa ok
upnover
tulsa ok
i went with hotchkis adj heim ended strut rods, and tubular heim adj uca's, cant remember who they were from though. works great.
thinking rms? on the uca's
[Re: Monte_Smith]
#1937895
10/24/15 07:27 PM
10/24/15 07:27 PM
dvw
MI, usa
The torsion bars and the rear steer is just a pain in the azz. Good headers and pan are nearly impossible with those in the way I agree this part is a challenge. My drag link goes thru the pan and each header is 4 piece. However it all comes apart pretty easy and fits well. Doug
[Re: sean1970]
#1938056
10/24/15 11:45 PM
10/24/15 11:45 PM
Posts: 43,321 Bend,OR USA
Cab_Burge
Whats the application? Drag race, street and strip, road racing or what?
[Re: J_BODY]
#1938123
10/25/15 01:50 AM
10/25/15 01:50 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I'm lazy... I don't like torture... I like easy... Tube k, rack steering, coil over shocks fit my needs to a "t". ....and it launches nice, comes down straight, drives straight, true, and tight. Room for engine diaper, headers can be weaseled out without even lifting the car in a pinch. I agree........I like EASY and as such, I am putting struts on the front of my GTX
[Re: sean1970]
#1938503
10/25/15 08:23 PM
10/25/15 08:23 PM
Cab_Burge
Be very inquistive as far as the ACTUAL weight on ALL suspension parts, I bought a fabricated tubelar K member for a early 1965 A body, it weighed 21 lbs and the stock 6 cylinder K member weighes 23 lbs Both where for stock front suspension with torsion bars and stock steering linkage and box and so on. I know many NHRA stock class rcers that took thier stock disc brakes off of their B and E body and put drum brakes on them from the same year car to loose front end weight Lots of choices out there on reducing weight, not all of them are the best choices Measure many times, buy once
[Re: sean1970]
#1938736
10/26/15 01:55 AM
10/26/15 01:55 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Light weight battery, like a 4# battery, carbon ceramic rotors, I would get a-arms that actually contact the bump stop. Tubular lower control arms. I like double adjustable shocks, just cant afford them. I am also putting on tubular sway bars. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
