Tool for cutting braided stainless steel hose?
#1936313
10/21/15 07:42 PM
10/21/15 07:42 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am pretty sure It is time to change the braided lines on my injection system. What is the life span of this stuff? It is Earls regular braided stainless steel hose. I am also looking for a cutting tool that will last, any suggestions?
Re: Tool for cutting braided stainless steel hose?
[Re: gregsdart]
#1936317
10/21/15 07:56 PM
10/21/15 07:56 PM
Challenger 1
Cincinnati, Ohio
I use my 10-12" abrasive chop saw on all sizes of braided lines, after I tape them with the correct tape. Then clean out the inside with a parts washer with mineral spirits before I assemble the ends. Made over 50 lines easy that way. Makes a super clean straight cut and I use a tool I already own. I replaced all my braided lines every 2 seasons, methanol is hard on lines. One plugged nozzle caused me a torched block, piston and head not to mention everything behind the engine burned up. IE wiring, Data cables, trans blanket and much more$ I raced with methanol for 15 years, 8 with a TAD. No front brakes and no throttle/rpm limiter.
[Re: gregsdart]
#1936319
10/21/15 07:58 PM
10/21/15 07:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
4-6" cut-off wheel in my 4" angle grinder with gorilla tape.
Mopar to the bone!!!
[Re: gregsdart]
#1936538
10/22/15 02:36 AM
10/22/15 02:36 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
On any fuel lines I like to use the TFE (teflon)lined stainless hoses. It last a lot longer than neopreme or viton line SS covered hoses, high temp. rated, high pressure and much better cororieve(SP?) resistance It used extensivelally in combat aircraft as well as other combat military applications
[Re: Monte_Smith]
#1936549
10/22/15 03:04 AM
10/22/15 03:04 AM
Cab_Burge
^^^^^^^^While all that is true.......it is also true that Teflon lined hose is heavy, not very flexible and both the hose and ends are expensive. I haven't weighed a foot of each type hose of the same sizez with aluminum ends on them so I don't really know about the weights of each, the TFE is usually a lot smaller O.D. than the non TFE hoses of the same size and your correct on the flexability of them, not good for sharp corners so I try to use 90 degree elbows ends for those applications.
[Re: gregsdart]
#1936551
10/22/15 03:07 AM
10/22/15 03:07 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Personally, I only use TFE for brake, clutch or nitrous lines.
I have also gotten away from the steel braided stuff period and gone to the black nylon outer braided hose. It's much lighter, has the same core and as an added bonus, you don't bleed after assembling ends on it..........LOL!!!
[Re: Monte_Smith]
#1936558
10/22/15 05:10 AM
10/22/15 05:10 AM
Posts: 624 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
I have also gotten away from the steel braided stuff period and gone to the black nylon outer braided hose. It's much lighter, has the same core and as an added bonus, you don't bleed after assembling ends on it..........LOL!!! ^ x 1000
[Re: gregsdart]
#1936568
10/22/15 08:11 AM
10/22/15 08:11 AM
gregsdart
Thanks, guys. I won't say how long it has been since my lines were changed, but they are waaaaaay over due. The cutter is the way I will go, because like Challenger I also plugged a couple of nozzles trying to use a chop saw. Even after a good cleaning with a bore brush and solvent, something stayed behind.
[Re: Monte_Smith]
#1936587
10/22/15 09:39 AM
10/22/15 09:39 AM
Challenger 1
Cincinnati, Ohio
^^^^^^^^While all that is true.......it is also true that Teflon lined hose is heavy, not very flexible and both the hose and ends are expensive. Yea I can't see having steel fittings on all my lines, would weigh too much, plus they only make it up to #6, what do you do on dry sumps and larger fuel lines.
[Re: gregsdart]
#1936591
10/22/15 09:55 AM
10/22/15 09:55 AM
Challenger 1
Cincinnati, Ohio
Thanks, guys. I won't say how long it has been since my lines were changed, but they are waaaaaay over due. The cutter is the way I will go, because like Challenger I also plugged a couple of nozzles trying to use a chop saw. Even after a good cleaning with a bore brush and solvent, something stayed behind. My problem came from a corroded fitting, not the hose or when the hose was made. Fittings and hose need to replaced after some time. The white stuff stuck in your nozzle is fitting not hose. I tried a shear years ago to cut hose, like said above it has to be really sharp, if not then your better off with a chop saw IMO.
[Re: Monte_Smith]
#1936720
10/22/15 02:50 PM
10/22/15 02:50 PM
Thumperdart
State of confusion
I have also gotten away from the steel braided stuff period and gone to the black nylon outer braided hose. It's much lighter, has the same core and as an added bonus, you don't bleed after assembling ends on it..........LOL!!! DITTO...........Plus I cut mine w/scissors or pvc cutters w/ease.......I now use the Earls lightweight hose and fittings $$$$$$
