Re: Custom Cams Grinds, Who do you have the best luck with?
[Re: DemonDust]
#1934931
10/19/15 02:11 PM
10/19/15 02:11 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
I've used crower and cam motion.
So far, the cam motion has been great and I haven't started the crower yet.
unions....the folks who brought you the weekend!
[Re: DemonDust]
#1934949
10/19/15 02:30 PM
10/19/15 02:30 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
Comp Cams, especially on custom grinds Thay seem to have the biggest selection of lobes of any of the better cam companys out there, I'm sure thier doing constant R&D also
[Re: DemonDust]
#1934991
10/19/15 04:08 PM
10/19/15 04:08 PM
Posts: 4,457 Washington
madscientist
Washington
I started using Cam Motion in 1998 and still do, but as of late we have had some differences of opinion on certain parameters but I will still say they are number one for grinding what you ask for. Garbage in, garbage out. You can't fudge numbers.
I still use Racer Brown a BUNCH because Jim and I see eye to eye on so much that it makes it hard not to at least get his numbers and see what he says. You can't BS Jim. My current project is using one of RB's grinds. He had the balls to hear me out, correct my erroneous thinking, and grind something dang close to what I thought I should have.
Jones Cams. Mike Jones is a smart dude. Have dyno'd a bunch of his stuff and it works. He has different ways of "skinning the cat", but the cat gets skinned .
Those would be my top 3 in any order, most likey I would chose the one who you "get on" with the best on the phone. I go by my gut. Also remember my gut is pretty old.
[Re: DemonDust]
#1935017
10/19/15 04:59 PM
10/19/15 04:59 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Dwayne Porter ground my custom cam for me and everyone I know with his cams are very happy. Ron
[Re: DemonDust]
#1935050
10/19/15 05:38 PM
10/19/15 05:38 PM
Posts: 4,209 New York
polyspheric
New York
What part of your tune up is such a departure from competitive engines that the cam has to be different?
Boffin Emeritus
[Re: DemonDust]
#1935061
10/19/15 06:03 PM
10/19/15 06:03 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Called a few companies. Many didn't know what an R5 was. Bullit has a guy who did all EEI Cams at comp. Howard's has Mikee who ground all Cams at Arrington. I have a couple predators for R5. Main thing is people who know the engine first. Then who grinds good Cams.
[Re: DemonDust]
#1935679
10/20/15 05:44 PM
10/20/15 05:44 PM
madscientist
Washington
That is the problem with comp. Unless you are "somebody" in the "biz" you just can't call and get ahold of anyone but a salesman, who picks cams from the same catalog or web site you can.
For the brave and daring (or the guys who are testing crap all day long) you can call comp and pick lobes out of the lobe profiles and put them together and have it ground. Me, being a nobody, tried it once, but the salesman convinced me it wouldn't work. Called someone else who custom did a cam and the lobes were pretty much what I picked from comp.
[Re: DemonDust]
#1935696
10/20/15 06:17 PM
10/20/15 06:17 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Scott Brown Competition Components
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: madscientist]
#1935698
10/20/15 06:20 PM
10/20/15 06:20 PM
Posts: 4,693 Wichita
GY3
Wichita
For the brave and daring (or the guys who are testing crap all day long) you can call comp and pick lobes out of the lobe profiles and put them together and have it ground. Me, being a nobody, tried it once, but the salesman convinced me it wouldn't work. Called someone else who custom did a cam and the lobes were pretty much what I picked from comp. I've ran bigger cams than that what he recommended in a stock stroke, stock head motor! Morons...
[Re: d7cook]
#1935707
10/20/15 06:30 PM
10/20/15 06:30 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I mainly use Tim Goolsby at Bullet (dealt with/have an account him for years and years going back to the Ultradyne days)...but I pretty much know what I want in terms of powerband/lift and duration based on cubes/headflows/Compression/gearing/stall and weight...and he helps pick the right lobe and spring requirements for how I intend to use the motor.
AND I would NEVER HESITATE to call Dwayne Porter (Fast68Plymouth) and get a Comp custom grind through him. Countless times we've come up with near identical grinds for Moparts applications. Guys would PM me and ask about a grind they either just bought from him (or were about to buy) and I think every time Dwayne picks the same basic grind, right down to the lobe spread and ICL. We must be kin somehow I think.
[Re: DemonDust]
#1935736
10/20/15 07:21 PM
10/20/15 07:21 PM
polyspheric
New York
X2 - someone who has done great work with those cylinder heads will know what they want for a cam.
Boffin Emeritus
[Re: DemonDust]
#1935820
10/20/15 09:43 PM
10/20/15 09:43 PM
crabman173
crabman173
I would bet that those nascar engines would be better left alone--yes..they are very high RPM packages that have it all moved up to the top--makes them hard to get a good drag race converter dialed in but...they are so well designed -to the point where I would think you would really screw up the combo asking some outfit that may have very little experience with that engine --for drag race use-- to make a good decision on a new grind I bet it goes backwards with new cam and that you have to start all over again with converter selection--again--very few converter builders with enough drag race experience with those engines. They are everywhere and cheap--my neighbor has one that is running great in a drag car but that was after a hard season and Lots of $$$$$ spent on converters. What do you hope to gain? And is a cam the way to make that gain? I bet converter is best way to attack going faster. All that being said I would call Arrington and stick with whatever they say just my two cents worth
