1973 Ebody Fender bolt size and stud locations? #1934500
10/18/15 09:40 PM
10/18/15 09:40 PM
South
Squirrel_Cat Offline OP
South
I am looking to pickup some fender bolts in bulk, not necessarily in kit form and am trying to find the size. I've seen some sites say 1/4"-20 and some say 5/16"-18. Which size is it?
Also I saw where 72+ had studs in some locations, which locations got studs and can the fender be installed in those locations with bolts? The only one I can think of is the one accessed through the forward door jamb
Thanks!
1973 340 'Cuda 2013 Mustang GT
Re: 1973 Ebody Fender bolt size and stud locations? [Re: Squirrel_Cat] #1934811
10/19/15 10:30 AM
10/19/15 10:30 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Fender bolts are 5/16 18.Studs (2) go at the bottom of the fender at the dog leg.
Re: 1973 Ebody Fender bolt size and stud locations? [Re: Squirrel_Cat] #1934832
10/19/15 11:18 AM
10/19/15 11:18 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Studs were used on the 3 center holes on the top of the fender apron.
2 on the rocker and 1 on the rear of the fender that goes to the cowl tab.
1 5/16 diameter washers up to 3/16 thick were used on the studs for alignment.
NMCA NSS 67 Coronet
