Re: WHERE DOES IT POINT?
[Re: Pynzo]
#1934044
10/18/15 12:24 AM
10/18/15 12:24 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It points in the direction of the nearest Toyota dealership where a brand new Prius is waiting for you to buy. Lol, I know how you feel. The FSM would have pictures and everything showing where it should point.
[Re: Supercuda]
#1934075
10/18/15 01:12 AM
10/18/15 01:12 AM
RapidRobert
Alright, Turn the dampener till it is at the initial amt you plan on running (15BTDC might be a good ballpark) & confirm you are on #1 compression & if not then go around another turn to get the slit back to 15. install dist so rotor points sideways across the eng (I'm rusty on BB's but I believe that is the OE position & OE is the best for plug wires). turn housing slightly till the magnet is dead even with the tooth. (not sure of can position but it needs room to be turned either way). Plug in the #1 wire in that over sideways cap terminal where the rotor is at and the rotor should be located pretty much directly under that cap terminal or at least close to it and the can will shift it CW (on a BB) from that at rest static position (rotor phasing) and then plug in the rest of the wires around CCW from there. Just do a visual or you can make a mark on the side of the dist directly under the center of the bulge of the #1 cap terminal then remove the cap & see if the rotor is centered or close to centered directly above your mark on the housing. No Mas
[Re: cogen80]
#1934201
10/18/15 12:02 PM
10/18/15 12:02 PM
RapidRobert
Magnum there are no dumb questions. holler how it turns out
[Re: Cab_Burge]
#1934930
10/19/15 02:09 PM
10/19/15 02:09 PM
RapidRobert
the #1 spark plug wire should be at 5 oclock position on the distributor cap with the vacume advance pointed straight up at 12 o clock. Looking at the distibutor cap spark plug wire holes #1 is just below the forward distributor cap spring steel retainer Cab is that clocking with a person in front of the car facing it? I have a 451 coming together (first BB in decades) & I like to maintain the OE plug wire routing
[Re: Magnumguy]
#1934941
10/19/15 02:20 PM
10/19/15 02:20 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I believe that's standing next to right fender by right front wheel, staring straight down at distrib.(providing eng is installed in car)
[Re: buildanother]
#1934944
10/19/15 02:23 PM
10/19/15 02:23 PM
RapidRobert
& you know now that you mention it that way that position sounds familiar (I heard it somewhere before way back). thank you!
[Re: Cab_Burge]
#1934948
10/19/15 02:29 PM
10/19/15 02:29 PM
RapidRobert
Cab I think you said it good I just was not grasping the position.
