B1 tool steel shaft rocker
#1933985
10/17/15 11:02 PM
10/17/15 11:02 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
I talked to chris (cam FX)about you B1 guys needing a tool steel shaft rocker as well, chris told me he just needed a sample and could do it easily.any one have a sample rocker to get the ball rolling? the tool steel rockers are lighter on the valve tip than a aluminum rocker, less deflection , needle or bushed tips,don't have the short cycle life that aluminum has.,and all parts are made right here in America. All ratios are available. Rockers are complete with tool steel shafts,tips and ajusters...pm me for details...LIFETIME WARRANTY!!! Tony
Re: B1 tool steel shaft rocker
[Re: Jerry Kathe]
#1934196
10/18/15 11:55 AM
10/18/15 11:55 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Great to hear someone that understands you can manufacture without the myths of hundreds of thousands of dollars in development costs. Also great to hear someone who is using their resources for the mopar community.....now whats the chances he has the capabilities for blocks and heads - lol! OR at least solid roller lifters and common shaft rockers that are adjustable on intake and exhaust for gen 3 hemi...
[Re: Jerry Kathe]
#1934236
10/18/15 01:11 PM
10/18/15 01:11 PM
boatracer572
San Jose Ca.
Great to hear someone that understands you can manufacture without the myths of hundreds of thousands of dollars in development costs. Also great to hear someone who is using their resources for the mopar community.....now whats the chances he has the capabilities for blocks and heads - lol! Chris builds roller lifters and rockers.... he wanted me to test the waters to see if there is enough interest to cad design, tool up and manufacture rockers for you guys
[Re: boatracer572]
#1939237
10/26/15 09:56 PM
10/26/15 09:56 PM
Posts: 4,213 New York
polyspheric
New York
FEA would remove quite a bit from that rocker.
Boffin Emeritus
[Re: polyspheric]
#1939345
10/26/15 11:43 PM
10/26/15 11:43 PM
boatracer572
San Jose Ca.
FEA would remove quite a bit from that rocker. As I said this is a older pic of a tool steel indy rocker....I was not aware of any other company's making tool steel rockers for any mopar head! The B1 rocker will have more weight saving near the roller tip, similar to the predator rocker....
[Re: Jeremiah]
#1939628
10/27/15 01:05 PM
10/27/15 01:05 PM
boatracer572
San Jose Ca.
Re: 440-1 Tool Steel Rocker
What kind of spring pressures are these good for? Single Shaft or paired? What is the pricing like? Are these designed around a specific installed height/valve length?
I'd be very interested in a set for our tunnel ram motor project. Any spring pressure you can through at it...Cam fx has these tool steel rockers on pro stock , pro mod and a host of othe classes...these rockers are avalible in eather paired shafts with rocker stands or a common shaft.... Chris has , is working with a bunch of the top names in nhra, Ihra,pdra,nmca .I will leave the pricing up to Chris.... Give him a call and tell him I sent you....LIFETIME WARRANTY on the rocker body.... Tony Cam fx (Chris Johnson ) 818 674 6155 ..
