Re: 65 Coronet Hemi Engine Location?
[Re: 410mopar]
#1933523
10/16/15 11:17 PM
10/16/15 11:17 PM
Posts: 4,848 Memphis
HemiRick
Memphis
They are very close on the passenger side. in my 68 Charger you have to unbolt and push down the top of the shock, to get the valve cover off. When changing valve springs there's no room to tap exhaust retainers to get them loose.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 410mopar]
#1933880
10/17/15 07:17 PM
10/17/15 07:17 PM
Posts: 11,657 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We did one in a 65 Coronet a number of years ago. Used a motor plate, centerline in the stock location as far as side to side. Moved it back as far as possible without modifying the firewall. Maybe lowered it a touch. We had to "slice" the right shock tower to clear the valve cover. Did a nice straight cut, welded a flat piece back in and cleaned it up. He wanted it period correct, but I couldn't bring myself to do the BFH mod. IIRC, we moved it about as far as we could without getting too close to the shock and we still had to loosen the top of the shock to get the VC off. Wish I had pictures.
I had a plastic long block to use, but didn't trust it. Was flimsy. Clearances were so close I used a real block to avoid any "oh $%!^s" when it was put together.
[Re: 410mopar]
#1934272
10/18/15 02:04 PM
10/18/15 02:04 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We moved the steering box on the car to get as much room for headers as possible. Was still close. I don't think the engine can be tweaked to the left without converting to a rack & pinion and/or aftermaket K frame. Then it all becomes fairly easy. But like I said, the owner wanted it period correct.
[Re: 410mopar]
#1934915
10/19/15 01:47 PM
10/19/15 01:47 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
use the plastic for mock ups, then do final fit with your real block and heads. the plastic is close.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
