Length of a 360 car dipstick tube, dipstick and oil capacity #1932200
10/14/15 08:01 PM
10/14/15 08:01 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
what is the length of a 340-360 car oil dispstick tube?
340-360 car dipstick length?
oil capacity of a stock 360 car pan with a short oil filter?
Re: Length of a 360 car dipstick tube, dipstick and oil capacity [Re: Joesixpack] #1932358
10/14/15 11:50 PM
10/14/15 11:50 PM
Bill I can get all that for you tomorrow ex just a guesstimate on the capacity which I'd say is 4 qts for the sump & maybe 1/2-3/4 qts for the short filter
Re: Length of a 360 car dipstick tube, dipstick and oil capacity [Re: RapidRobert] #1933015
10/16/15 02:05 AM
10/16/15 02:05 AM
I did not get over there today (stuff came up unexpectedly)) but tomorrow for sure & its at the top of my to do list
Re: Length of a 360 car dipstick tube, dipstick and oil capacity [Re: Joesixpack] #1933208
10/16/15 01:47 PM
10/16/15 01:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
BTW, different years different lengths. 3418933 for 70-74 dipstick tube is 7.875 and 3462049 dipstick is 16 3/4 I have always used 5 quarts with no issues.
Re: Length of a 360 car dipstick tube, dipstick and oil capacity [Re: mopars4ever] #1933453
10/16/15 09:14 PM
10/16/15 09:14 PM
I got 11" & 1/16 on the tube and 21" & 3/16 on the dipstick on a 318 and 6&5/8 on one 360 tube (no stick in it) and 6&3/4 on the tube and 16&5/16 on the dipstick on another 360. Bottom line is the level in the sump & I would put 4qts in the sump on a level surface & wherever that falls at on the stick is "full" no matter what the filter capacity is.
Re: Length of a 360 car dipstick tube, dipstick and oil capacity [Re: Joesixpack] #1933801
10/17/15 03:05 PM
10/17/15 03:05 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Can't help you with the length, but the factory spec for a 1980 360 engine is:
1) 4 qts w/o oil filter change
2) 5 qts w/ oil filter change
Here is what I did to re-establish the LOW & HIGH levels (following the original engine start-up, break-in, etc, etc), given that I replaced the stock tube with the shiny (chrome..lol) MP kit (tube & dip-stick).
1) totally empty system, add 4 qts
2) start engine, shut off after a couple of minutes, let oil drain back to the pan
3) pull dip-stick, clean, re-insert and note the oil-level
4) mark the oil-level as the LOW spot on the dip-stick, I drilled a small hole in the dip-stick to give me that mark
5) add 1 qt to bring the total level to the spec 5 qts
6) repeat #2 & #3 from above
7) mark the oil-level as the HIGH spot on the dip-stick, I drilled a small hole in the dip-stick to give me that mark
