Liquids for Freeing Stuck Engine #1932851
10/15/15 10:36 PM
10/15/15 10:36 PM
New Jersey
P
Powerflow Offline OP
P
New Jersey
I hope I'm wrong but I'm concerned that the 361 in my '66 Sport Fury may be stuck, even though I oiled it up before mothballing 18 years ago. I've read that a 50/50 mix of acetone and automatic transmission fluid works well, but separates after a while. Is this so? My other choice would be a mixture of Marvel Mystery Oil and kerosene. Are there any other concoctions I can try? Thanks for any ideas.
Harold
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932852
10/15/15 10:38 PM
10/15/15 10:38 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
Kroil!
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932856
10/15/15 10:42 PM
10/15/15 10:42 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
There are a LOT of guys at yellowbullet.com that think AMSOIL is the greatest thing since the birth control pill.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932869
10/15/15 10:55 PM
10/15/15 10:55 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
What Amsoil?
Have a great day
Iowan
"obsolete is neat"
Re: Liquids for Freeing Stuck Engine [Re: Kern Dog] #1932878
10/15/15 11:03 PM
10/15/15 11:03 PM
IN
ahy Offline
ahy  Offline
IN
The Marvel Mystery Oil or Kroil should help.
Now a story (true). I worked at a boat yard once. One of the customers 440 powered boats sank in salt water... something silly like a sea cock opened. The boat was raised after a day or so and a day or so later the 440 was pulled, drained and immediately dropped in the outboard test tank. The test tank had fresh water a bit oily from testing 2 stroke outboards. It sat there for about a month. When the mechanic was ready to work on it, he pulled it out, drained it again, put some oil in the cylinders and got a long breaker bar. It was stuck. The breaker bar got it turning. With electrical parts replaced, it was re-installed and fired up. Ran fine. Far as I know, no problems afterwards.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932881
10/15/15 11:06 PM
10/15/15 11:06 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
GIBBS.....Farmers use it for freeing up equipment left out year round..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932902
10/15/15 11:34 PM
10/15/15 11:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The best thing you can do to try and free the engine is to not just try to turn it one direction, but to work the crank back and forth. Sometimes it takes a lot of twisting back and forth before much progress is made. And be sure to let it set and soak with your chosen penetrant for several days.
Master, again and still
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932928
10/16/15 12:02 AM
10/16/15 12:02 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've tried and had luck with marvel 1/2, atf 1/4 and kerosene 1/4.
Also use the flywheel to turn the motor (as above) both ways a little at a time. Keep working at it. If you end up feeling a catch or jamb when rotating figure a imminent teardown.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1932974
10/16/15 01:01 AM
10/16/15 01:01 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I don't know if its true but I've heard Coke as in Coca-Cola will free up a stuck motor.
Have a great day
Iowan
"obsolete is neat"
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933058
10/16/15 04:09 AM
10/16/15 04:09 AM
Castlegar, BC, Canada
That AMC Guy Offline
I do a three-day treatment using a concoction of diesel, ATF and WD-40.
This mixture has yet to meet an engine it couldn't break free.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933059
10/16/15 04:18 AM
10/16/15 04:18 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've used turpentine a couple times.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933147
10/16/15 11:58 AM
10/16/15 11:58 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
PB Blaster here ... oh ... and a hammer ...
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933232
10/16/15 02:31 PM
10/16/15 02:31 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
PCL Break Free. Some fire departments use it to free stuck hydrants. I've used it to free linkage and motors that were stuck.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Liquids for Freeing Stuck Engine [Re: Iowan] #1933256
10/16/15 03:12 PM
10/16/15 03:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, the phosphoric acid in Coke eats rust.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933339
10/16/15 05:53 PM
10/16/15 05:53 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've used Marvel Mystery Oil and Coke with good results. Aero Kroil would do it, too.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933541
10/16/15 11:45 PM
10/16/15 11:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard good things about filling the cylinders with diesel and letting it sit.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1933613
10/17/15 01:02 AM
10/17/15 01:02 AM
New Jersey
P
P
New Jersey
I'll try to get to it this weekend and then give it a week or so to soak.
Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1934110
10/18/15 02:54 AM
10/18/15 02:54 AM
what liquid are you gonna use!
UPDATE Re: Liquids for Freeing Stuck Engine [Re: RapidRobert] #1934386
10/18/15 06:03 PM
10/18/15 06:03 PM
New Jersey
P
P
New Jersey
GOOD NEWS: I went outside earlier to tag the plug wires before removing them. Decided to see what happens if I put a socket on the crank pulley bolt. With hardly any effort, the pulley turned! I only moved it a few degrees but at least I know it turns.
Afterwards, I went rummaging in my cabinet and found some very old Marvel Mystery Oil (we're talking 20+ years). Does it go bad? Same question for kerosene(I've got that lying around also).
I'm on a budget so if I don't have to buy anything I already have it's a plus.
At this point, unless it's not a good idea because the stuff is so old, I think I'll put a little of my Marvel in each cylinder as a light lubricant.
Thanks again for your support.
Harold
UPDATE Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1934493
10/18/15 09:23 PM
10/18/15 09:23 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Get it to move then use ATF in it.
Have a great day
Iowan
"obsolete is neat"
