Re: Liquids for Freeing Stuck Engine
[Re: Powerflow]
#1932881
10/15/15 11:06 PM
10/15/15 11:06 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
GIBBS.....Farmers use it for freeing up equipment left out year round..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: Powerflow]
#1932902
10/15/15 11:34 PM
10/15/15 11:34 PM
Posts: 12,019 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The best thing you can do to try and free the engine is to not just try to turn it one direction, but to work the crank back and forth. Sometimes it takes a lot of twisting back and forth before much progress is made. And be sure to let it set and soak with your chosen penetrant for several days.
Master, again and still
[Re: Powerflow]
#1932974
10/16/15 01:01 AM
10/16/15 01:01 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I don't know if its true but I've heard Coke as in Coca-Cola will free up a stuck motor.
Have a great day Iowan
"obsolete is neat"
[Re: Powerflow]
#1933058
10/16/15 04:09 AM
10/16/15 04:09 AM
Posts: 4,793 Castlegar, BC, Canada
That AMC Guy
I do a three-day treatment using a concoction of diesel, ATF and WD-40. This mixture has yet to meet an engine it couldn't break free.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: Powerflow]
#1933059
10/16/15 04:18 AM
10/16/15 04:18 AM
Posts: 20,167 Park Forest, IL
slantzilla
Park Forest, IL
I've used turpentine a couple times.
[Re: Powerflow]
#1933147
10/16/15 11:58 AM
10/16/15 11:58 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
PB Blaster here ... oh ... and a hammer ...
[Re: Powerflow]
#1933232
10/16/15 02:31 PM
10/16/15 02:31 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
PCL Break Free. Some fire departments use it to free stuck hydrants. I've used it to free linkage and motors that were stuck.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Iowan]
#1933256
10/16/15 03:12 PM
10/16/15 03:12 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I don't know if its true but I've heard Coke as in Coca-Cola will free up a stuck motor. Yep, the phosphoric acid in Coke eats rust.
[Re: Powerflow]
#1934110
10/18/15 02:54 AM
10/18/15 02:54 AM
RapidRobert
I'll try to get to it this weekend and then give it a week or so to soak. what liquid are you gonna use!
UPDATE Re: Liquids for Freeing Stuck Engine
[Re: RapidRobert]
#1934386
10/18/15 06:03 PM
10/18/15 06:03 PM
Posts: 1,294 New Jersey
Powerflow
New Jersey
I'll try to get to it this weekend and then give it a week or so to soak. what liquid are you gonna use! GOOD NEWS: I went outside earlier to tag the plug wires before removing them. Decided to see what happens if I put a socket on the crank pulley bolt. With hardly any effort, the pulley turned! I only moved it a few degrees but at least I know it turns. Afterwards, I went rummaging in my cabinet and found some very old Marvel Mystery Oil (we're talking 20+ years). Does it go bad? Same question for kerosene(I've got that lying around also). I'm on a budget so if I don't have to buy anything I already have it's a plus. At this point, unless it's not a good idea because the stuff is so old, I think I'll put a little of my Marvel in each cylinder as a light lubricant. Thanks again for your support. Harold
[Re: Powerflow]
#1934493
10/18/15 09:23 PM
10/18/15 09:23 PM
Iowan
Lost in Time
Get it to move then use ATF in it.
"obsolete is neat"
