Moving Battery to trunk, do you have to have a shut off
#193273
01/14/09 03:18 PM
01/14/09 03:18 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'd like to move the battery to the trunk of my wife '68 Cuda but since it's also a street car I do not want to put a shut off on the back of the car.
It's my understanding that there is an IHRA/NHRA rule requiring one but I was wondering if there was also and ET break for when it's required or does it not matter what ET, if you have it in the trunk you have to have an external shut off?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Moving Battery to trunk, do you have to have a shut off
[Re: WadeMetzinger]
#193274
01/14/09 03:22 PM
01/14/09 03:22 PM
Posts: 146 michigan
tonycpe
michigan
Batt relocated to trunk = rear shut off for all power . you knew you knew the answer.
Old Fogey Racing Ltd.
[Re: WadeMetzinger]
#193275
01/14/09 03:30 PM
01/14/09 03:30 PM
Posts: 1,178 Indy
FlyFish
Indy
Yes you have to have one. On my 67 cuda its right through the center of my license plate.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#193276
01/14/09 03:36 PM
01/14/09 03:36 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
What most guys who are opposed to the look do, is use a push pull type of switch.
then you run the rod for the knob/switch through a small hole in whatver part you like.(a lense or behind the plate, or whatever)
Then, when not in use just unthread the rod, and put it in the glove box.
[Re: dave571]
#193277
01/14/09 03:38 PM
01/14/09 03:38 PM
Posts: 5,080 organ
maximum entropy
organ
not only do you have to have a shut off at the back of the car, but the battery needs to be in an nhra approved box vented to the out side, or you need a rear firewall. bolted down with minimum 3/8 studs x2.
[Re: dave571]
#193279
01/14/09 03:41 PM
01/14/09 03:41 PM
Triple Threat
Renton Washington
There are ways to make it easier and less conspicuous on a street car. Through the license plate, under a tail light.
My car is just as much of a street car as a race car, With glass bumpers I said screw it and just mounted it in the bumper as normal. The handle is close to body color though so it doesn't stick out quite as much. Never been hassled in tech about it either.
[Re: dave571]
#193280
01/14/09 06:16 PM
01/14/09 06:16 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
That is a great Idea.
I used a push/pull on Gina's car and was concerned about someone bumping it while we were driving on the street.
I used one of the existing hole in the bumper to put the rod through. If you have any it's an alternative to drilling into the body. I did have to ream it a little larger. But, if you take the rod out, you'll never notice.
[Re: Aspen7695]
#193283
01/14/09 10:48 PM
01/14/09 10:48 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
What about the newer Chrysler products that come with the battery factory mounted in the trunk? I've seen them running at the track without a shutoff switch or a battery box.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#193284
01/14/09 11:07 PM
01/14/09 11:07 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Ah-Ha!!! A can of worms here???
[Re: superwrench]
#193285
01/14/09 11:12 PM
01/14/09 11:12 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
IIRC, it's required IF you move the battery from the factory location.
No worms on the loose
[Re: racealittle]
#193286
01/14/09 11:13 PM
01/14/09 11:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Don't need a box.
Post deleted by Defbob
[Re: Leadfoot]
#193289
01/14/09 11:32 PM
01/14/09 11:32 PM
[Re: dirtybee]
#193291
01/15/09 12:11 AM
01/15/09 12:11 AM
Posts: 7,863 Colorado
Leadfoot
Colorado
So now we have three wires going from the trunk to the front. 1 Big one and 2 little ones. Alternator and battery go to the left side and out the right side we go to the starter with the big one and the relay with the little one. I think I get it now.
[Re: Leadfoot]
#193292
01/15/09 12:13 AM
01/15/09 12:13 AM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
wha? i got to go to bed but i've been trying to figure out how to make my 2 post moroso shut off switch work ever since i bought it over a year ago soi'll check back in 2morrow. thx, dave
