97 ram , back up lights
#193263
01/14/09 03:07 PM
01/14/09 03:07 PM
Posts: 146 michigan
tonycpe
michigan
I replaced the back-up lights / neutral safety switch in my 97 ram 1500 cause it was leaking a little.
Now i have no back up lights . A full systems check revealed that the pin in both new switches that we checked would not extend enough to complete the circuit once the switch was installed.
the neutral safety works fine.
Has anyone ever heard of this?
Old Fogey Racing Ltd.
Re: 97 ram , back up lights
[Re: crlush]
#193265
01/14/09 03:13 PM
01/14/09 03:13 PM
Posts: 146 michigan
tonycpe
michigan
I bought one at the Dodge dealer and one at carquest. don't know where they were made .
Do you have any better of a answer?
[Re: tonycpe]
#193266
01/14/09 04:20 PM
01/14/09 04:20 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Did you try both switches out of the transmission? If the pin extends and closes the circuit when out of the trans but not when installed there might be damage to the plastic shoe inside the trans.
[Re: John_Kunkel]
#193267
01/14/09 05:33 PM
01/14/09 05:33 PM
Posts: 146 michigan
tonycpe
michigan
Yes , i tried both out of trans and they worked i believe it is in the trans .
what is this plastic shoe , Does it fall out of place ? Is it easy to fix or replace..
I'm kinda surprised the neutral safety works fine.
Thanks for your help.
It a chore backin up at night out here in the boonies.
