Re: Cost of 900 hp in a N/A small block?
[Re: Jimi_Vignogna]
#1932373
10/15/15 12:17 AM
10/15/15 12:17 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you read the internet and listen to guys at the track...........there is a swinging dick on EVERY street corner with an inline valve, wedge smallblock, that makes over 900HP. I have been doing this stuff for a LONG time and have NEVER seen one, be it a Ford, Mopar or Chevy. As I said, you can do it with some canted valve stuff, but it's still not REAL easy and will be at a min of 40K if you do it with all new stuff.
I have done several 434ish Chevys and Fords, with the BEST 15-18* heads you can buy. A good one will make between 840 and 880, depending on cam, compression, rotating weight, etc. I have yet to see a Mopar head that was BETTER than the best off brand, so I am going to say it can't even realistically be done with an inline head........regardless to what some dyno sheets may say to the contrary monte it can and has been done with the w8 stuff , my 390 was 920hp,ran 8.30@ 163.00 2850#, my uncle has a rwr 393 w8 that is 940hp 8.50's high 150mph @ 3100#, my avenger has a 300" w8 that is 705 I have run 9.05 @149.00 @ 3000# . all 13 degree head engines. NA in super stock cars. not one of these engines were under 40K . a few guys are selling p5 heads that are not cracked or leaking for 12 to 15 K. incase anyone is interested my 300" r3 w8 engine is for sale carbs to pan $15,000.00 . or the entire car for $45,000.00 Again Jim........many mistook the point I was trying to make. In Comp, Super Stock and some other trims, with sheetmetal manifolds, dry sumps, ultra-light bobweights, super low drag ring packs, etc, etc, the in question number is attainable, but lets face it, those type motors are few and far between. I was speaking more along the lines of what the average guy is going to do. Sure, he may have some KILLER cylinder heads that would be up to the task, but it's the REST of the motor, where making the jump from the 850-880 range to over 900 is where the issue lies. And I wasn't trying to insinuate the guy with the Valiant was lying or anything like that.......but we all know this is a HARD, very hard in fact goal to achieve and just a run of the mill motor is not getting it done. His mph for the weight car, indicates he is about 20 shy of the "magic" number. Do I believe his motor makes the 880 the mph indicates.......absolutely I do. The 934hp the ET indicates............well I have my doubts. That's a 50hp swing in numbers, so the real number is likely in between. My dad ran a SS/GA car for years that was a record holder. WE did the motors......me and him, so regardless of what some may think, I know EXACTLY what is required to get more power from a combo than most think is there. There was 40hp difference in our "record" motor and our "race" motor. One needed freshening in a handful of passes and the other would go the season. THAT is the difference, but of course you KNOW all this.
[Re: 408strokerdart]
#1932461
10/15/15 05:32 AM
10/15/15 05:32 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I didn't know this would be such a hotly debated topic when I posted it.
It just took a bad turn when some people put THEIR OWN limitations on the build. You asked a blanket question - 900 NA H/P = how much. Others created the drama with all THEIR limitations, such as inline valves, new vs old parts, etc. Bottom line is - there is no simple answer. The guy that can shop wisely - including "seasoned" parts, use patience while buying parts, get his machine work done CORRECTLY at reasonable prices, and can do a lot of his own grunt work will pay dimes on the dollar to the guy that buys all new stuff and just writes a check when the pump shows 900 HP. And here's the real rub. People that use MPH as a true gauge of H/P must be clueless to ALL of the things that affect trap speeds. Weight is obvious. Driveline loss is too, to a certain extent. Engine accessories - I've never seen anybody use a working alt on a dyno pull (at this level). The smarter ones will start to consider the aero package, and that resulting drag. But something NOBODY ever seems to grasp is that a dyno cell is not a real world scenario to the airflow introduced to the carb. While you can jet for max installed H/P - it does not mean you are making the H/P that it did on the dyno. You may gain H/P by having an efficient hood scoop/air pan setup that draws air from a cool high pressure area. But you can also lose it by drawing your air from a hot low pressure area. Look how much power Pro Stock cars lose at Denver - same thing - lower effective "air pressure". There can easily be a 50 H/P swing from the most honest dyno numbers to the H/P the engine actually makes in the car. And I'm sure there are other things that affect the H/P to MPH equation. Point is - there are too many variables to use the weight/MPH ratio as a way to accurately judge an engine in all cases.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Monte_Smith]
#1932473
10/15/15 08:32 AM
10/15/15 08:32 AM
Posts: 428 wappinger falls new york
Jimi_Vignogna
Monte was just giving a few more examples not trying to second guess your knowledge, the Wallace calculators which I use from time to time seem to be (3%) on both sides, hp is always a bit high with et.always low with mph. In most of the super stock modified cars they never show what they should actually run according to dyno hp,if they did my car in ss/bm with a p/s truck 358 should run 8.00 to 8.10 , I never ran that with the 390". Two more cars I can think of are Scott Gove,his car is stupid fast he has been in the 7.90 zone not sure if it's a p5 or w8 and Paul Ricci with his avenger I know is a w8 and has been very close to the 7 second zone, both of those are well over 900 hp on hp. I don't have the mega cubic dollar budget to buy multiple $4000.00 torque converters ,$3500.00 headers,tires,gears,carbs etc. I know you know the drill and that what it takes.
[Re: Jimi_Vignogna]
#1932521
10/15/15 11:33 AM
10/15/15 11:33 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Brian is just a regular guy on a budget like most of us. He has a really good combination. But, struggles like everyone else when trying to be repeatable with one of these combos.
I just get pissed by the guys that say it is easy. Or even they can do it. When the fact is many of us have built or had help or bought one of these engines. Flow numbers from 390-420 and HP from 850-1000 posted. Most of us are not stupid. If you don't have the mph then you don't have the HP. Or at least when the engine is in your car the power is just not there. If you 60ft is out of shape the guess what so is your et.
Brian really posted an impressive pass. His et was great but had a great 60ft. His mph was also stought t,o there you go, HP.
Now everyone thinks Brett is the only guy who knows W8's. Well that's just BS. Many people have ran better ET's and mph over 10 years ago. The difference is Brett doesn't bend you over to help you do so. I dealt with a lot of the ground scorchers in the early 2000's. Many were pretty decent until you wanted port or intake work. Or complete engines they wanted to put you in bankruptcy. Today if doing one of these I would use Kevin Blanks for block work if he had the time and head work definitely call Brett Miller. I just can't afford the Pro Stock NHRA guys.
Brett
Leon
[Re: Leon441]
#1932572
10/15/15 12:58 PM
10/15/15 12:58 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Brett
Leon where did you read someone said it was easy
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: MattW]
#1932706
10/15/15 05:14 PM
10/15/15 05:14 PM
Posts: 1,019 Finland
mafo
Finland
Here I was on a vacation in Greece, warm ,sunny, good beer and beautiful women, and you are having fun here... I don t know what the cost would be since I have bought most of my stuff used+ paid shipping,24% sales tax and customs fees,but it isn't cheap, don t know if I have 900 but I will post a dyno chart, I have 10 less inches and a tad lower comp ratio and unleaded fuel [img:center] [/img]
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
#1932725
10/15/15 06:04 PM
10/15/15 06:04 PM
Posts: 4,210 New York
polyspheric
New York
A dyno read is exactly as good as the honesty of the operator. Read Vizard for how many Indy, NASCAR, F1 dyno results have been "adjusted" to please the customer.
Boffin Emeritus
#1932857
10/15/15 10:43 PM
10/15/15 10:43 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Just need to add, "low maintenance and pump gas" to the question and we might lose a few guys to cardiac arrest...
Mopar to the bone!!!
[Re: WHITEDART]
#1933000
10/16/15 01:44 AM
10/16/15 01:44 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Leon
where did you read someone said it was easy Sasquatch's quote: "The R5P7 deal will do it easy... Fishy340's quote: "Jeremy @ Extreme will have a sb wedge out next year with a 420 intake and single carb that will eclipse 900 easy... Only two examples I could find...I swore there were more...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#1933024
10/16/15 02:17 AM
10/16/15 02:17 AM
MoparBilly
Phoenix, AZ
I can't keep the 904 alive with 600HP and a small shot...
[Re: MoparBilly]
#1933029
10/16/15 02:23 AM
10/16/15 02:23 AM
WHITEDART
bean town ....Ca
Leon
where did you read someone said it was easy Sasquatch's quote: "The R5P7 deal will do it easy... Fishy340's quote: "Jeremy @ Extreme will have a sb wedge out next year with a 420 intake and single carb that will eclipse 900 easy... Only two examples I could find...I swore there were more... r5 p7 has the potential to make well over a 1000hp there a ton of Cleveland sbf making over a thousand similar style head
[Re: WHITEDART]
#1933032
10/16/15 02:26 AM
10/16/15 02:26 AM
WHITEDART
bean town ....Ca
I'm sure that'll start another fire
