Re: Who makes 1.81 exhaust valve with 0.370" stem?
[Re: JS23U]
#1932648
10/15/15 03:17 PM
10/15/15 03:17 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
How much clearances will you have between the guides and valve stems with those valves? I like to see a minimum of.0018 on the intakes and .0020 or more on the exhausts on a pump gas street motor If there more than .0035 then I have the guides fixed
[Re: JS23U]
#1934658
10/19/15 02:42 AM
10/19/15 02:42 AM
Posts: 494 IL
EchoSixMike
IL
You want a small hole gauge. A calipers isn't the tool for this. http://www.goodson.com/Small-Hole-Gauge-Set/I'd have the tips ground, then use lash caps, if the valves are still straight and the margins are still ok. S/F....Ken M
[Re: EchoSixMike]
#1934699
10/19/15 04:04 AM
10/19/15 04:04 AM
Cab_Burge
You want a small hole gauge. A calipers isn't the tool for this. http://www.goodson.com/Small-Hole-Gauge-Set/I'd have the tips ground, then use lash caps, if the valves are still straight and the margins are still ok. S/F....Ken M Thats the correct tool, I have heard them called ball mikes also from the day I bought mine many years ago simple and easy to use and they will tell you if the insides of the guides are straight or not I've measured many new guide liners that where coke bottle shaped inside
[Re: JS23U]
#1934792
10/19/15 09:32 AM
10/19/15 09:32 AM
Posts: 494 IL
EchoSixMike
IL
Yep, heard them called ball gauges or ball mics too. If you know you're just measuring valve guides, you can just get a .300 to .400 gauge. http://www.mscdirect.com/browse/tn/Measu...?navid=12107846I'm sure these are available in Germany, that's the land of precision machining. Probably have 'em in the local quickie mart, lol. S/F....Ken M
