Which seal for disc front brakes? #1932275
10/14/15 10:13 PM
10/14/15 10:13 PM
WA
tman Offline OP
tman  Offline OP
WA
Have a 70 Cuda with front disc brakes. Will be changing rotors during winter. I found the correct inner and outer bearings, but mixed up on which seal is correct. All the parts guides that I can find including Rockauto show different seals for 10 inch or 11 inch brakes. Does not say which one for disc brakes.
So for those that know, which seal is correct? Please give a brand and part#.
Thanks.
Re: Which seal for disc front brakes? [Re: tman] #1932388
10/15/15 12:36 AM
10/15/15 12:36 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The disc brake spindles are unique for the disc brakes. Buy the seals for the disc brake rotors, might have to look at 71 Brake rotors. The 10" and 11" drums have different spindles as well.
If all that fails, do the bearings for the rotors match the 11" brake bearings? Gene
Re: Which seal for disc front brakes? [Re: poorboy] #1932435
10/15/15 02:42 AM
10/15/15 02:42 AM
WA
tman Offline OP
tman  Offline OP
WA
Im told that the 10 and 11" bearings are the same for drums and disc. Now the seal is a mystery.
Even the catalogs say bearings for 10 and 11 inch brakes are the same, but no mention of disc brakes.
Hope someone knows which seal is correct. Don't want to buy both sizes.
Re: Which seal for disc front brakes? [Re: tman] #1932459
10/15/15 04:58 AM
10/15/15 04:58 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Cass has the wear rings bearings & seals!
Re: Which seal for disc front brakes? [Re: m88mark] #1932470
10/15/15 07:36 AM
10/15/15 07:36 AM
IN
ahy Offline
ahy  Offline
IN
If necessary, take the old ones into a good NAPA store and they will match them up. Likely to be in stock... or order from Dr Diff as mentioned.
Re: Which seal for disc front brakes? [Re: tman] #1932485
10/15/15 10:06 AM
10/15/15 10:06 AM
Mass
charge70 Offline
charge70  Offline
Mass
Thanks.
The seal for 11" drum brakes is correct for disc brake rotors. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Which seal for disc front brakes? [Re: tman] #1933986
10/17/15 11:03 PM
10/17/15 11:03 PM
WA
tman Offline OP
tman  Offline OP
WA
Thanks for the answer. Finally looked up specs for the 10" vs 11" seal. The inner and outer diameter is the same for both seals. The shoulder is a bit wider for 11" brakes.
