Page 3 of 12 1 2 3 4 5 11 12
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931727
10/13/15 11:18 PM
10/13/15 11:18 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Originally Posted By Monte_Smith
Originally Posted By ValiantRich
The R3 W8 380" motor in my Valiant made just over 900 on 2 different dyno's. At 3080# I ran best of 8.67 at the Dutch Classic this past weekend. The new parts and machine work cost about $35k if you assemble yourself.
Sorry, I simply don't believe it makes that much.
AndyF.........the only reason I mentioned an inline head was the price range some were throwing around, an inline was the only thing to be in the neighborhood on cost. If you are not used to building high HP motors and you know the motor that you have that makes 700hp costs X amount of dollars......it is hard for most to fathom that 200 more hp will likely triple the budget at least. I mean......it's ONLY 200hp more.........right, how tough can that be.......LOL!!!
I didn't bring Comp motors, Aussie Pro-Stock and that type stuff into the conversation, because that stuff is in another world
Maybe you don't but I do, His car Top Notch and has been around Divison 1 for a while.
SS/BM Richard Kay 8.67 He set record at the Dutch for his class.
Switched to the dark side...
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931728
10/13/15 11:20 PM
10/13/15 11:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Would it be too big of a a stretch to say the drive-train soaks up 20 HP?
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931731
10/13/15 11:24 PM
10/13/15 11:24 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
If you don't start from scratch, like already 600hp with a set of -1 heads
How much more you have to spend to be in the 800hp range ?
Dan
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931733
10/13/15 11:26 PM
10/13/15 11:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
153 mph
Based on ET and weight, Wallace says 934hp.........based on MPH and weight, Wallace says 880hp............So now, do we know any more than we did before...........NOPE
so we don't believe dyno number, we don't believe calculated numbers.... So should the title of this thread be "Cost of an X mph N/A small block?" ??
...figured a turbo guy would have to ask "why?".
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931737
10/13/15 11:31 PM
10/13/15 11:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I do read these posts, but apparently not everyone here does. No where in Brian's post did he mention inline valves, canted valves, single four, dual four tunnel rams or any other exclusion.
This is my take, 900HP, NA, small block and carb to pan. Please point out what I missed. Here is a copy and paste.
"Mopar guys seem to have a reputation of being "cheap" in general, but I know some of us that are not.
I'm just trying to get a feel from some on this board on what they think 900 hp should cost in a N/A small block...carb to pan. I know there are other options for 900 hp that might be cheaper, but thats for another topic.
There are a few here that know the answer to this question, but would like to hear from a few that haven't been down this road yet."
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931740
10/13/15 11:40 PM
10/13/15 11:40 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
You said it all with this. "I do read these posts, but apparently not everyone here does. No where in Brian's post did he mention inline valves, canted valves, single four, dual four tunnel rams or any other exclusion"
Re: Cost of 900 hp in a N/A small block? [Re: Bigcube] #1931742
10/13/15 11:43 PM
10/13/15 11:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By Bigcube
Originally Posted By Al_Alguire
This is what I don't get....
930 HP / 580 ft-lbs with tunnel ram intake with dual holley 4 bbl carburetors
890 HP / 570 ft-lbs with single plane intake manifold and holley 4 bbl carburetor
Torque is what moves the car.
I'll stay out of it now.
You can multiply TQ with lower gears to get more TQ, you can not do that with HP. You have to get more HP to go faster. Very simple concept but so out of grasp of so many. That being said I prefer not having to gear my car so low to go fast so I tend to want lats of cubes in a small package.
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931785
10/14/15 12:37 AM
10/14/15 12:37 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
If you read the internet and listen to guys at the track...........there is a swinging dick on EVERY street corner with an inline valve, wedge smallblock, that makes over 900HP. I have been doing this stuff for a LONG time and have NEVER seen one, be it a Ford, Mopar or Chevy. As I said, you can do it with some canted valve stuff, but it's still not REAL easy and will be at a min of 40K if you do it with all new stuff.
I have done several 434ish Chevys and Fords, with the BEST 15-18* heads you can buy. A good one will make between 840 and 880, depending on cam, compression, rotating weight, etc. I have yet to see a Mopar head that was BETTER than the best off brand, so I am going to say it can't even realistically be done with an inline head........regardless to what some dyno sheets may say to the contrary
we'll I always in joy or input always controversial and backed by a lot's of personal experience how ever only making 840to880 shows your lack of engine building experience Prostock truck ran an inline valve W8. And there are many many many comp eliminator Motors that have all achieve 900 + horsepower with an inline head
Jesus H Christ......does nobody even READ the damn posts. I implicitly said that Pro-Stock Truck and Comp motors were NOT in the discussion, because they are in a whole nother world. Was talking run of the mill, single carb, real world motors, with 15-18* wedge heads, like most people build.......NOT 10,000 rpm motors, built for clutch cars or motors for 1400lb roadsters in Comp eliminator
Seems impossible on this site, for anyone to take anything within the context of the ENTIRE discussion. They want to take ONE thing you said in ONE post, run with that comment and ignore everything else.
You guys carry on...........I'm out
you said Ozzy Pro Stock and comp you never said anything about pro stock truck unless I missed it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Cost of 900 hp in a N/A small block? [Re: WHITEDART] #1931795
10/14/15 12:48 AM
10/14/15 12:48 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Monte if you read the original question how much does it cost to build a 900 horsepower small block you're the one exempting rpm and cubic inches and comp motors and Aussie Prostock has nothing to do with the original question come back we will put more salt in your wound.. I could build 900 horse all day long for 25/30 grand with a good set of 8s or 9s CNC programs have cut the cost significantly on this type of motor... the biggest problem with A Mopar is block availability
Re: Cost of 900 hp in a N/A small block? [Re: Al_Alguire] #1931802
10/14/15 01:00 AM
10/14/15 01:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Take that and put a 3.60-3.80 stroke in it and it might be more of beast but the 9" deck kinda limits things.
Mopar to the bone!!!
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931823
10/14/15 01:16 AM
10/14/15 01:16 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Thanks for asking the question Brian popcorn
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931837
10/14/15 01:35 AM
10/14/15 01:35 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Since the question was " what they think a 900 hp na sb should cost" Ill stand by 26k and not a penny more
You guys get poor Monte so worked up
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1931838
10/14/15 01:37 AM
10/14/15 01:37 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I agree with you
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931841
10/14/15 01:47 AM
10/14/15 01:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I know of Rich's car as well. I am also sure he will concur an SS motor built to BM standards is no cheap piece to build. Could also easily be run in Comp but that is DEEP water for sure in what would be a B/SMA or even A/SMA deal likely, based on similar cars I have seen that run both and depending on cubes. Those are some mighty impressive SB's for sure. Also not run of the mill by any means. Rich's car is very impressive to say the least and doing it in a class full of late model Cobalts, G6's etc it is even more so.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931845
10/14/15 01:56 AM
10/14/15 01:56 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I don't know...what should it cost, 25K-50K? What is someone willing to pay might be a more pertinent question.
I've never really looked at the price of entry as the be all, end all...what I really want to know is, how much does it cost to race, and maintain?
Would it be a valve springs every 10 passes engine? What's the life expectancy of say... rockers, valves, lifters, piston rings, bearings?
Not being sarcastic, I'm completely serious, because this is where the true cost of an engine manifests itself, not the sticker price to bring it home!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Cost of 900 hp in a N/A small block? [Re: MoparBilly] #1931847
10/14/15 02:03 AM
10/14/15 02:03 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Putting a price tag on an engine such as this is near impossible. Some guys do nothing and the smart ones do everything. It cost BIG money to pay someone to do everything.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931864
10/14/15 02:54 AM
10/14/15 02:54 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Build an AMC with FBS heads...
Re: Cost of 900 hp in a N/A small block? [Re: 451Cuda] #1931898
10/14/15 09:45 AM
10/14/15 09:45 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
This whole thread is nutz. Guys saying they can build 900 with w8-w9's all day long, really. I don't know if you guys pay attention but many of these dyno champs do not even run 150 in a 3000 lb car on good days. A 900 HP build should trip 150 in the worst air. On a good day should run close to 158. If it doesn't either you have a car problem or a dyno operated that is doing something wrong. If same guy built it and took your money he needs a bruised eye.
If you know where the deals are and have some luck you could build for $10k. I did it once with my 457cid in 2000 with 100% American parts. Shops wanted $35,000 to $60,000.
Blocks and good cnc work is where you get creamed. Between Arrington selling me a block for $1,500 and Davis doing the block work I only had $3,000 in the block. Patterson sold heads to me and flat hooked me up on parts. The rockers I got in a trade that cost me $100. Point I'making this just never happens. Five years later I built a 421 cid. The block I got for $600 and did not need the cam tunnel bored and still ended up $10K through a shop. Lucky I had the top end already.
And you wonder why I went R5. Little hard work doing headers, fitting drysump, and an adapter done. People complain about adapter. I designed a bell. Tubular k fits dry sumps. And most people have headers built. 830hp out of a 358. EEI will build 1,000hp for $60,000. I'm sure Frank Lysing and others will do for less. My pockets are not that deep. And my stuff only makes 900 based on mph. But, was cheap for me.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931921
10/14/15 11:01 AM
10/14/15 11:01 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I paid 2400 for machine work done on a virgin block from Charlie Westin cam tunnel 60 mm w berrings,lifter bores bushed,bored,honed,decked.
Holy shishkabob 9600 for block work on a 600 dollar block.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931923
10/14/15 11:06 AM
10/14/15 11:06 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I know where you can get a bunch of R3 with W8 Comp stuff for quite reasonable. A very dedicated and smart man has been trying to make it work in Comp for years and just couldn't do it. He was north of 750 on 300'ish inches, and over $20k in dyno time.
Frankly, these kinds of projects, you need to start with a blank check and lots of crying towels. 900HP is just an arbitrary number, what do you want to do with the engine? What are the rules? S/F....Ken M
