Wiindshield crank on my truck is stuck #1926728
10/06/15 12:41 AM
10/06/15 12:41 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
The windshield crank that cranks the windshield open and closed is stuck open, I lubricated it real good a few weeks ago. Can I access the mechanism if I remove the upper dash by removing the 8 upper screws and 6 lower screws?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1926836
10/06/15 06:46 AM
10/06/15 06:46 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
It's been a long time since I pulled mine, but as I recall......
Pull the 2 screws that hold the arm to the windshield frame.
Remove the handle,(fold out the crank and remove the center screw under it to remove the crank).
There should be 2 screws under the chrome bezel. When those are removed the whole assembly should drop out.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1927307
10/06/15 09:27 PM
10/06/15 09:27 PM
moparx Offline
moparx  Offline
if possible, please post pics of the assembly when it is out. thanks !
beer
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1928779
10/09/15 12:51 AM
10/09/15 12:51 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
This isn't for this pat of the project, it's for the doors you worked on earlier.
However, I just ran across it again and thought I share, since you always need to undo more stuff on these ol cars and trucks
http://www.jalopyjournal.com/forum/threads/tech-tip-309-rusty-screw-removal-made-easy.6015/
Re: Wiindshield crank on my truck is stuck [Re: RodStRace] #1928787
10/09/15 01:07 AM
10/09/15 01:07 AM
Dreaming of the 808
Dreaming of the 808
f
What a great idea, will make one myself, thanks
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1929304
10/09/15 10:29 PM
10/09/15 10:29 PM
moparx Offline
moparx  Offline
f
i second that ! up i haven't been over to the hamb in a few years even tho i'm a member, but some of those guys come up with some very clever problem solvers ! thanks for sharing that tip !
beer
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1929306
10/09/15 10:31 PM
10/09/15 10:31 PM
Lehigh Acres, Florida
rickstershemi Offline
Whatever Happened to the good old Impact Driver....Still Have mine from 30+ years ago and works flawlessly .... if I find a head that is too messed up I will sacrifice a tip or socket and just tack weld it on ... then hit it with he hammer and 99% of the time it's loose JM .02
Rickster
Re: Wiindshield crank on my truck is stuck [Re: rickstershemi] #1929348
10/09/15 11:19 PM
10/09/15 11:19 PM
moparx Offline
moparx  Offline
i still have a snapon impact driver i bought in 1970, and still use it on occasion. however, my eye sight and hand/eye coordination ain't 'zactly like it used to be, and boy, does my hand hurt and turn funny colors when i miss my intended target. grin[one of my old man's favorite sayings was "it will fell better when it quits hurttin'...."]i'm always open to new methods that will ease the pain.
beer
Re: Wiindshield crank on my truck is stuck [Re: moparx] #1930603
10/12/15 01:33 AM
10/12/15 01:33 AM
Dreaming of the 808
Dreaming of the 808
beer
Here you go
Re: Wiindshield crank on my truck is stuck [Re: moparx] #1930605
10/12/15 01:35 AM
10/12/15 01:35 AM
Dreaming of the 808
Dreaming of the 808
beer
All apart
Re: Wiindshield crank on my truck is stuck [Re: AZ_A12_BEE] #1931090
10/12/15 10:05 PM
10/12/15 10:05 PM
moparx Offline
moparx  Offline
thanks for the pics ! up now, are my eyes telling me the worm gear on the toothed gear that pulls the strap [for lack of a better word] in and out slightly stripped in the middle ? or did you find something else that prevented the mechanism from working ?
beer
