Re: Brake booster conversion
[Re: z70dodge]
#1930818
10/12/15 01:24 PM
10/12/15 01:24 PM
RapidRobert
A booster does not so much add braking power as it does reduce pedal braking effort (downside is it reduces braking "feel"). Are you having a specific issue (as is) that we might be able to address? Or were you going to power discs?
[Re: z70dodge]
#1930900
10/12/15 03:32 PM
10/12/15 03:32 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The drum brake MC push rod hooks directly to the brake pedal, the PB booster hooks to the pedal through linkage...you'll need the linkage and a different firewall reinforcement plate in addition to the booster.
