01 Durango hang shift? #1930215
10/11/15 03:12 PM
10/11/15 03:12 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
2001 Durango, 4.7, 2wd, 178k miles. Just changed the fluid about 5k miles ago. No problems until recently. Under more than half throttle, the engine will rev, sit at whatever rpm (say 3k) for about 5 seconds or so, then shift to the next gear. If I'm easy on the gas, it shifts no problem. Fluid is full, doesn't smell funny at all. It shifts funny into all gears, but it seems worse into 3rd and 4th. No check engine light or od light. Any thoughts? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 01 Durango hang shift? [Re: GTSDart340] #1930877
10/12/15 02:52 PM
10/12/15 02:52 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe swap out the solenoid pack?
Re: 01 Durango hang shift? [Re: GTSDart340] #1931639
10/13/15 08:58 PM
10/13/15 08:58 PM
places
79powerwagon Offline
places
Make sure the cable or linkage for the kick-down still works as it should. I fixed a late 90's 1500 that was headed for the repair shop with a can of PB Blaster and some patience getting it to work again. It's an easy place to start!
Re: 01 Durango hang shift? [Re: 79powerwagon] #1931776
10/14/15 12:27 AM
10/14/15 12:27 AM
IN
ahy Offline
ahy  Offline
IN
Not quite the same symptoms but close would be a bad TPS sensor. Basically the transmission is getting bad throttle position information and does not know what to do. I had this problem on a 5.9 Durango... fix was pretty easy. An external part of the TB with pigtail and connector.
