wheel width and offset for 68 GTX #1929556
10/10/15 12:24 PM
10/10/15 12:24 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
car has all stock location rear suspension and original rear housing and axles
how wide and what offset wheel will fit ,with as wide a tire as possible?
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1929682
10/10/15 04:49 PM
10/10/15 04:49 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
On my 68 Satellite: 15x8, 4.5 bs , 275/60-15 fits great
Re: wheel width and offset for 68 GTX [Re: forphorty] #1929751
10/10/15 07:41 PM
10/10/15 07:41 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Assuming wheel wells would be the same 68 GTX to a 70 Satellite I have a 5.5 backspace on a 9.5 wheel. You can't get aggressive with a wide tire with that much wheel. I added a 1/4 spacer on the inside of mine to increase the clearances. I think 5" would be the most you could get away with comfortably. twocents
...FAFO...
Re: wheel width and offset for 68 GTX [Re: skicker] #1929769
10/10/15 07:56 PM
10/10/15 07:56 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I had a set of factory (Ramcharger?) 15x8 wheels on my GTX with M/T 275/60-15's. I liked them.
Stan
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1929841
10/10/15 10:18 PM
10/10/15 10:18 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I think we cover this every week, but I like posting these pictures, I just think it looks so cool. 68 RT Coronet with 10 inchers and 4.25 back space, I'm gonna tell you it's about perfect. I have a set of 10 inch cop wheels with 5.25 backspace and the tires hit the springs on my 69 RT Charger, might work with a tire with less section width but I wouldn't go much over 4.5 back space to leave plenty of room and unless you go wider than 10 inches you will well inside the wheel well lip. twocents
Careful, your character's showing!
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1929891
10/10/15 11:13 PM
10/10/15 11:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
10" with 5-1/2 bs on my 69 RR
Re: wheel width and offset for 68 GTX [Re: Stanton] #1931342
10/13/15 12:34 PM
10/13/15 12:34 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I run a 15x10 rear wheel 4-3/4 backspace with a 325-50-15 Nitto Drag radial on the rear of my 68 gtx. I do have the outside wheel lips rolled for clearance. You should be able to use a 15x10 wheel with a 5" or 5.5" backspace with 295-50-15 with no issues. I also run a 15x8 wheel upfront with 4.5 backspace and a 275-50-15 with no issues.
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1931768
10/14/15 12:14 AM
10/14/15 12:14 AM
mopar346 Offline
mopar346  Offline
That's a lot a front tire.
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1946863
11/07/15 12:26 PM
11/07/15 12:26 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
what about up front?
15 x 7?
and tires, we like the solid raised white letter
T/A Radials
Goodyear Eagle ST
forspd340 thought 275/60's would work on the 8" rears.
what about the front?
Re: wheel width and offset for 68 GTX [Re: 4spdana] #1946875
11/07/15 12:45 PM
11/07/15 12:45 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
or maybe do 15x8's all the way around?
with a different width up front?
car is manual steer
Re: wheel width and offset for 68 GTX [Re: forphorty] #2045103
04/03/16 09:30 AM
04/03/16 09:30 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
the 15 x 8's , is that all the way around?and same tire's up front?
