Page 18 of 22 1 2 16 17 18 19 20 21 22
Re: Let the Hemi swap begin [Re: AlexP] #1929264
10/09/15 09:07 PM
10/09/15 09:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I see the zinc but I don't trust it.
There are tooling marks and scratches on the metal. If anything gets through the zinc it can corrode like a cheap chrome wheel.
- Stu Harmon
Re: Let the Hemi swap begin [Re: AlexP] #1929270
10/09/15 09:20 PM
10/09/15 09:20 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Meh. Surely there are other areas on these old cars to lose sleep over while worrying about corrosion. twocents
...less worry, more driving Alex!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let the Hemi swap begin [Re: AlexP] #1929297
10/09/15 10:20 PM
10/09/15 10:20 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The rest of the car is corroded. That doesn't worry me. Just a might as well add on to the car.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1929368
10/09/15 11:53 PM
10/09/15 11:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
How did this engine swap turn into a suspension thread? COME ON MAN lol!
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: AlexP] #1929380
10/10/15 12:20 AM
10/10/15 12:20 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
It's kinda been about everything I'm doing. I'm bored like that haha.
Back to the engine swap tomorrow.
Re: Let the Hemi swap begin [Re: AlexP] #1929908
10/10/15 11:41 PM
10/10/15 11:41 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Update of the day:
I found radiator hoses for a B-body with a 26" radiator opening and a Champion Hemi swap radiator. Just universal gates green hoses and they fit really well. I'll post the numbers up tomorrow.
Oil temperature and oil pressure gauge is in. Had to take the alternator off but it was worth it.
Cooling fan brackets are almost mocked up. Just need a little bit more work.
Also, my spring swap is complete. The car is sitting really nicely with the 2x right side XHD springs, 2" steel lowering blocks and the AR engineering front spring hanger set on the -1" setting.
Re: Let the Hemi swap begin [Re: AlexP] #1929920
10/10/15 11:50 PM
10/10/15 11:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Killer!
'63 Dodge 330
11.19 @ 121 mph
Re: Let the Hemi swap begin [Re: AlexP] #1930262
10/11/15 04:54 PM
10/11/15 04:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Oh yeah, I like it a lot!
Re: Let the Hemi swap begin [Re: AlexP] #1930385
10/11/15 07:54 PM
10/11/15 07:54 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Looks awesome but I'd be worried about a little side to side wiggle.
- Stu Harmon
Re: Let the Hemi swap begin [Re: AlexP] #1930533
10/11/15 11:52 PM
10/11/15 11:52 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Once I roll the lip, I'll have even more room. Doesn't worry me.
Re: Let the Hemi swap begin [Re: AlexP] #1930559
10/12/15 12:42 AM
10/12/15 12:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You have twice as much room between the tire and fender than I had on my 72 Swinger, and that was after I rolled the inner fender lip. I had a bit less than one finger width between the tire and leaf spring and it would just slightly rub under hard cornering, not enough to hurt the rubber but just enough to keep the leaf shiny in that one spot.
Don't be the exception.
Re: Let the Hemi swap begin [Re: AlexP] #1930582
10/12/15 01:07 AM
10/12/15 01:07 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The leaf spring clearance was about an inch before the spacer. 5" bs is the sweet spot for this car on a 9" wheel.
Re: Let the Hemi swap begin [Re: AlexP] #1930715
10/12/15 10:13 AM
10/12/15 10:13 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You need 94-04 Mustang wheels then.
Re: Let the Hemi swap begin [Re: AlexP] #1930728
10/12/15 10:44 AM
10/12/15 10:44 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
So you have 2" of leaf spring clearance and 2 fingers of fender lip clearance? Consider me envious! That's a 315 all day long.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: AlexP] #1930970
10/12/15 06:26 PM
10/12/15 06:26 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
can you get a pic of the leaf spring arch with the car at rest?
are they pretty much flat?
Re: Let the Hemi swap begin [Re: AlexP] #1931038
10/12/15 08:39 PM
10/12/15 08:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's a bunch more room than it looks like in the other pic.
The hot rod rears rubbed the outer wheelhouse about 3 inches above the opening. I introduced it to the Rubber Enforcer and got the clearance I needed.
- Stu Harmon
Re: Let the Hemi swap begin [Re: AlexP] #1931440
10/13/15 03:01 PM
10/13/15 03:01 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
Awesome car!!! This is what hot rodding is all about...taking a sweet looking old car and putting in a superior modern engine (and suspension). Great build, cool idea, and I think we all can relate the problems on the old engine, oil leaks, gas smell, reliability, etc. Thanks for sharing, I am a neophyte to the suspension and engine upgrade scene so I really enjoy seeing builds like this that aren't using the magic of television.
thumbs
Re: Let the Hemi swap begin [Re: nutso suave] #1932118
10/14/15 04:59 PM
10/14/15 04:59 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
thumbs
Thanks, you've basically summarized what I expect and want from the car.
I want to build it to be left alone. I want to not have leaky cork gaskets, a tune that doesn't need to change with the weather, to be able to drive the car day in, day out with out rolling the windows down or smelling like fuel....
Get in, take off a minute after starting it and getting onto the freeway with a range that I decide. The silly fast speed I expect from 550hp in a relatively light weight combo is the best part.
This is all being done in my driveway, with no special tools or super expensive parts with the help of some really good friends. Wade, Mike and Brian all come to mind.
I won't say that this swap is cheap or for everyone. My case is unique and this car is swapped for about half the cost of the average person but I've horsetraded and stashed parts for 3 years before I turned a wrench on it. I saved a ton of money by being broke and patient.
Re: Let the Hemi swap begin [Re: AlexP] #1932182
10/14/15 07:15 PM
10/14/15 07:15 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
In the past, I enjoyed the tuning of the old 340, COMP XE268 and thermoquad, but with the wide temperature swings we have in Houston in the fall, winter (Ha!) and spring, the daytime temps can be from the 30's -> 90's (October 14th today and it's 94 as I write this).
I also want to be able to drive this car (Assuming I ever get it back from the body shop) anywhere in all weather conditions and be able to cruse down the freeway @ 75Mph all day long with the A/C running (Passion 5-speed, 3.73's 285/35-18's), approach or exceed 20Mpg and run 118Mph in the 1/4 mile as well as stop and handle with a modern muscle car.
Thanks to Alex (Assuming he's right!) and Wade and Steve, both our motor are essentially identical and my '71 Duster should be a couple of hundred pounds lighter than Alex's '68 Runner.
This should be a fun, go anywhere, do anything resto-mod Duster. Hopefully it's first outing at a track will be at Royal Purple Raceway in February and the Big Bend Open Road Race in April! Time will tell...
1971 6.1 Gen III Hemi Duster
Re: Let the Hemi swap begin [Re: AlexP] #1932353
10/14/15 11:39 PM
10/14/15 11:39 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
thumbs
thumbs thumbs thumbs thumbs
2020 RAM 1500
