How to take dash out of 68 Charger #192918
01/13/09 11:22 PM
01/13/09 11:22 PM
Louisiana
duckblind Offline OP
Louisiana
I am trying to take the dash out of my 68 charger. There is some rust up underneath the dash and a bunch of crud from 40 years of life on the road. Is this an easy job? Does anyone know of a book or an article somewhere that describes how to take everything apart?
Re: How to take dash out of 68 Charger [Re: duckblind] #192919
01/13/09 11:28 PM
01/13/09 11:28 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
I wouldn't call it an easy job.
The windshield and seal has to come out to get access to the screws along the front edge.
The sides are held in by one bolt on each side.
Other than the obvious wires, cables and everything else.
Re: How to take dash out of 68 Charger [Re: SNK-EYZ] #192920
01/13/09 11:39 PM
01/13/09 11:39 PM
Louisiana
Louisiana
How do you take the windshield out other than with a baseball bat?
Re: How to take dash out of 68 Charger [Re: duckblind] #192921
01/14/09 01:06 AM
01/14/09 01:06 AM
A Red State
A Red State
The 1st step is to remove the outer trim.
That requires a trim molding tool.
pic from Harbor Freight Tools
After that the outer rubber seal has a lock channel rubber that must be pried out.
After that start spraying down the entire outer perimeter of the glass and seal with soapy water (for lubrication).
Next you basically push and work the glass out from the seal.
If you're lucky you can do it without breaking the glass.
That's about the easiest way I can explain it.
Good Luck!
Re: How to take dash out of 68 Charger [Re: SNK-EYZ] #192922
01/14/09 02:18 AM
01/14/09 02:18 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The glass will also most likely have a ton of sealer on it and will require you to use a guitar string, piano wire or buy the glass removel tool with a cutter and handle..
I used a couple of cans of PB blaster on the last on to help disolve the glue.
NOT a fun or easy job, plan on buying a new windshield and gasket.
Re: How to take dash out of 68 Charger [Re: sthemi] #192923
01/14/09 08:23 AM
01/14/09 08:23 AM
Louisiana
Louisiana
Is it fairly easy to find a new windshield, in case I break the old one?
Re: How to take dash out of 68 Charger [Re: duckblind] #192924
01/14/09 08:25 AM
01/14/09 08:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yup, but this is not a wekend project. the heater/ac assembly will have to come out, along w/ all the duct work, steering column...and on and on. take a picture or draw out something so you can reference where stuff goes.
Re: How to take dash out of 68 Charger [Re: Mr.Yuck] #192925
01/14/09 08:40 AM
01/14/09 08:40 AM
Louisiana
Louisiana
Duct work? Most of that has dry rotted out. Thanks for the advice. I normally take pictures when I start to yank stuff off of the car. It took me about a year or so to realize that there is very little that I can do to the car in a weekend. I used to think that I could do every thing in a weekend. Now, I realize that it all takes time and that it is better to try and do things right the first time. Case and point, I pulled the carpet up to change and noticed the floor pans are in worst shape than I thought. So I ripped out pretty much all of the interior of the car in order to check for more rust. Everything looks good with the exception of some surface rust spots back of the dash and a couple of very rust spots back of the dash. Also, the dash is the only part of the car that has never been painted. So, I figure as long as I have the inside mostly apart, I just as soon take the dash off, try and clean up some of the rust behind it and then paint the dash. That way, when I put the interior back in, I want have the urge to take the dash out because the rust in the back of it is bugging me.
Re: How to take dash out of 68 Charger [Re: duckblind] #192926
01/14/09 08:43 AM
01/14/09 08:43 AM
Louisiana
Louisiana
I learned my lesson swapping out the 360 that came in the charger for a 440....more work than I thought...but it is worth it.
Re: How to take dash out of 68 Charger [Re: duckblind] #192927
01/14/09 09:55 AM
01/14/09 09:55 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
If the car is a non a/c car there is no need to remove heater box to get dash out. You may be able to get it of an a/c car without removal as well but I am not certain. Just disconnect the defrost tubes and heater control cables. The dash will lift out over the heater box.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
