Page 2 of 3 1 2 3
Re: Engine plate with stock water pump & alternator tech help [Re: an8sec70cuda] #1928262
10/08/15 11:04 AM
10/08/15 11:04 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I put a East Coast Auto mini on mine, works good but looks like it came off a Kubota tractor. lol
Re: Engine plate with stock water pump & alternator tech help [Re: dartman366] #1928443
10/08/15 04:00 PM
10/08/15 04:00 PM
I've always used a stock Moapr alternator on the motors with elephant ears and front motor plates until I got my current Cuda, I use a Powermaster 100 amp single wire GM style on it do to it not having a charging system on it. My Duster with the 400 pump gas stroker motor had a OEM 45 amp Mopar alternator on it until it died, I bought a Tuff Stuff brand 100 amp Mopar bolt on replacement from Summit, that work very well up scope More amps when needed is way better than not quite enough work
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928462
10/08/15 04:39 PM
10/08/15 04:39 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
I would entertain making a bracket for a newer Mopar style alternator.
I'll deal with the charging problems before I put any GM related parts on my Mopar. I'm sure I should buy a cowl hood to right?.....
lol
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928474
10/08/15 05:07 PM
10/08/15 05:07 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
lol
A cowl hood would look better than any of the mopar scoops on yor Dart.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928676
10/08/15 10:49 PM
10/08/15 10:49 PM
Portland, Oregon
Digger73 Online rolleyes
Digger73  Online Rolleyes
Portland, Oregon
This is what I did for my 65 Plymouth.
[img]<a href="http://s1028.photobucket.com/user/digger731/media/IMAG0143_zpsiiuqygyf.jpg.html" target="_blank"><img src="http://i1028.photobucket.com/albums/y349/digger731/IMAG0143_zpsiiuqygyf.jpg" border="0" alt=" photo IMAG0143_zpsiiuqygyf.jpg"/></a>[/img]
I'm new to this photo adding stuff so please bear with me.
I guess I don't have the magic to post pictures.
Sorry.
I can email them if you PM me with your email.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928711
10/08/15 11:37 PM
10/08/15 11:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yea cuz dealing with charging problems all the time is so relaxing and fun lol. And yes a cowl hood would look sweet on your Dart.
Here's my Toyota alternator.....
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928713
10/08/15 11:37 PM
10/08/15 11:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Kinda hard to see when it's mounted low.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928714
10/08/15 11:39 PM
10/08/15 11:39 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
This is the AR-Engineering kit to install it on a motor plate.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928756
10/09/15 12:29 AM
10/09/15 12:29 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
What ProSport said..."Use the AR-Engineering plate, it's nice. I use it along with a stock type water pump housing, I haven't had it milled because my pulleys line up good. But I only have 2.75 inches between the water pump snout and my radiator, so I use a cheap flex fan along with a shroud.
I use a Toyota Denso alternator and will never go back to a mopar setup, it's small, mounted low, and charges at 14 volts at all times, best setup I've ever owned. I'm sure alot of guys have the mopar setups ironed out but I always had problems with them."
Ditto...have 71 Dart, 440-727, TTI. Go with AR-Engineering plate, it has proper off-set with RB in A-Body which will be important in ensuring TTI fit and function. Went with Denso Alternator and did some of my own fab on top mounting it (stock alternator location) with the motor plate.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928881
10/09/15 10:06 AM
10/09/15 10:06 AM
an8sec70cuda Offline
lol
rolleyes Can't argue w/ this logic. rolleyes
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928900
10/09/15 10:54 AM
10/09/15 10:54 AM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
lol
Are building a street car or race car as I see you asking about glass doors in another thread...If your trying to go fast ya may be in trouble with all MOPAR parts,LOl.
Here's my 7 second street legal car with a gm hood & trans along with a ford rear...Mine's all steel except for hood & bumpers !!
Re: Engine plate with stock water pump & alternator tech help [Re: Gary Robbins] #1928906
10/09/15 10:59 AM
10/09/15 10:59 AM
Idabel,Oklahoma
Idabel,Oklahoma
My Dart with a gm hood and aftermarket alt...Does have a 904 trans & S60 rear tho !!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928955
10/09/15 12:25 PM
10/09/15 12:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gary I think he would rather run the 14.28 @ 93 if it meant he could stay with all mopar parts
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1929093
10/09/15 03:34 PM
10/09/15 03:34 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Chevy hoods, Ford 9"s, and don't forget the power glides! lol
Hey if it works great. I am just not a fan of GM designs, and have always had bad blood with the 85% of GM population that races in my area.
I appreciate the help and advice though guys!
Re: Engine plate with stock water pump & alternator tech help [Re: ProSport] #1929095
10/09/15 03:34 PM
10/09/15 03:34 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
That is sweet!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1929325
10/09/15 10:49 PM
10/09/15 10:49 PM
Try and remember, by owning and racing a "Mopar" your going against the grain to start with shruggy Being strong enough to do what you want only makes you stronger thumbs devil Many people on here have really good intentions, many cars guys, no matter what brand they like, think thier way is the only, thier wrong down workKeep on keeping on thumbs
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1929437
10/10/15 03:06 AM
10/10/15 03:06 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Any part that is BETTER or makes my car BETTER, I use it, no matter who made it or where it came from.
Nobody but YOU will likely care that your Mopar is 100% Mopar.....and that's fine if you want it to be that way, but it seems that you or anyone else would simply want your cars to perform better. If that's a better charging system, front suspension, rear suspension, trans, rear, whatever...........no need to handicap yourself even more.
If your Dart still has the stock 68 wiring, electrical system and alternator.........lets face it, good it's NOT. Not with all the high amp draw "cool guy" parts some run these days. When you are sitting at a light and rev the motor and your headlights get brighter, you know the electrical system leaves something to be desired.
Re: Engine plate with stock water pump & alternator tech help [Re: Monte_Smith] #1929444
10/10/15 03:57 AM
10/10/15 03:57 AM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
Best upgrade I ever did with my ride was to rewire the whole car and upgrade the alternator to a "Chevy" one wire one with the low mounting alternator kit... No more flickering lights at idle and weird issues with the ignition and other electrical headaches... Only regret is I should have bought a 140Amp instead of the 100Amp I bought... and NO ONE has ever mentioned to me when looking under the hood of my ride that -You have a GM alternator...
/Tom
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1969779
12/14/15 11:02 PM
12/14/15 11:02 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Done
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1969792
12/14/15 11:12 PM
12/14/15 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Oh the humanity...... smile
Page 2 of 3 1 2 3
