Radiator and fan set up Small Block Dart #1928323
10/08/15 01:08 PM
10/08/15 01:08 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I am thinking I need to up grade my cooling system in my Dart.
Right now I have Aluminum radiator , 12 " pusher fan and a Moroso belt driven water pump set up (old School) It was pretty cool out last night and I was running just @200 degrees between rounds
looking for some suggestions on what everybody else is running.
Switched to the dark side...
Re: Radiator and fan set up Small Block Dart [Re: JSR1485] #1928390
10/08/15 02:53 PM
10/08/15 02:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
Pullers are always going to be better than pushers. How much room do you have to work with? I ran a Chevy HHR fan with good success.
That water pump set up isn't doing you any favors either.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Radiator and fan set up Small Block Dart [Re: JSR1485] #1928415
10/08/15 03:18 PM
10/08/15 03:18 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Puller (1 big or 2 small) with a shroud. If you don't use a shroud to force the air to come through the radiator, it doesn't matter how big it is. With a proper set up, you'd be surprised how small of a radiator would be sufficient.
Re: Radiator and fan set up Small Block Dart [Re: CMcAllister] #1928450
10/08/15 04:16 PM
10/08/15 04:16 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I agree
I have the same room as most SmallBlock A-bodies like 5 3/4 "
I was looking at a Be-Cool set up with a Moroso 63565 Water Pump
How are the Champion set ups with the fans, radiators and shrouds?
