Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1917837
09/23/15 01:15 AM
09/23/15 01:15 AM
fullmetaljacket
This memo followed in theory right on the heels of the Hemi SS package cars. These were really covert and super trick. AKA The Reeker Files. Now ya'll know where the madness started.
#1926417
10/05/15 06:15 PM
10/05/15 06:15 PM
Thumperdart
State of confusion
Why no cal-tracs?
[Re: Thumperdart]
#1927248
10/06/15 07:50 PM
10/06/15 07:50 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I'll start adding to this thread now. I havent even read all of this thread. The 4 washers on the strut arms are almost a lb. 14.8oz to be exact. I just bought 4 grade 8 washers and they weigh 4.2 oz. So over half pound easy and cheap
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1927265
10/06/15 08:13 PM
10/06/15 08:13 PM
sixpackgut
Charleston
According to my person scale. I lost 1 lb on the spindle on the left
[Re: sixpackgut]
#1927356
10/06/15 10:34 PM
10/06/15 10:34 PM
fullmetaljacket
These spindles are interesting. They seem a little hint different from each other. I believe in Andy Finkbeiner's recent book "B-body performance upgrades" there is mention of a lighter later year spindle. I don't really know if this will apply to A-bodies though.
Did you also grind away at the top portion of the spindle on the left?
I would suggest not to grind at these pieces to much being that they are cast to be strong at different points and some bosses are integral to strength. Be careful out there and study it all before going forward. Measure twice, then measure again just before the cut as they say.
Very soon there will be some interesting ultra super tricks added here and abroad. Keep an eye out.
[Re: Thumperdart]
#1927376
10/06/15 11:11 PM
10/06/15 11:11 PM
sixpackgut
Charleston
If i was using rubber bushings I would have went with a cupped washer but the poly bushings I dont think it matters one bit.
After I cut a section of the spindle off, I used a die grinder and took off the casting ridge all the way around so yes its narrower but I think in a good way. I still think more could come off
[Re: Thumperdart]
#1930615
10/12/15 01:43 AM
10/12/15 01:43 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
go for carbon ceramic rotors, save about 15 lbs...tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
