440 build...suggestions
#192746
01/13/09 09:17 PM
01/13/09 09:17 PM
Posts: 908 North Chicagoland
newbee69
North Chicagoland
Hey guys, A guy by me is trying to get rid of a 440 short block. I might pick it up, but Im looking for build suggestions before I get it 74 block .30 steel crank KB 237 pistons, moly rings LY rods, arp bolts Clevite bearings I figure this would be a great starting point for a nice street build. I would want to add a six pack setup on the top as this would be going in an A12 clone. I would like to get about 10+ comp, run on pump gas, and get about 500 hp. I would like it to be more of a torque monster than a high end screamer. Suggestions on heads and cam? 915? 906? Eddys? Procomp? about 2.14/1.81? roller rockers? Any help and suggestions are appreciated. Thanks.
Re: 440 build...suggestions
[Re: newbee69]
#192747
01/13/09 09:29 PM
01/13/09 09:29 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Myself I would get something with closed chambers when it comes to the heads. Or can those pistons achieve quench with open chambered heads?
Moparlee
[Re: DaytonaTurbo]
#192750
01/13/09 10:49 PM
01/13/09 10:49 PM
newbee69
North Chicagoland
Wow, thats a good price on those 440 source heads. That looks like the way to go. Just have to deck the block. What do you think the CR would be without decking? Pistons are rated at 10.2 with 85 cc heads. What about cam? Thanks for help guys.
[Re: Stanton]
#192754
01/13/09 11:53 PM
01/13/09 11:53 PM
newbee69
North Chicagoland
Thanks for clearing that up Daytona and Rapid. Im still learning. Although, if the block wasnt decked, then wouldnt that increase the piston to head distance, creating detonation and bad squish, but also lower CR? Not trying to argue, just learning. Stanton, I dont want to go the NOS route, but its a good idea. I would like to achieve 500 HP, but it doesnt need to be there. I am surprised to hear that the source heads dont flow well enough though. They seem to match up, number wise, to Eddys which Ive seen on plenty of 500+ hp builds.
[Re: newbee69]
#192755
01/14/09 12:03 AM
01/14/09 12:03 AM
DaytonaTurbo
Manitoba, Canada
Yes. Having .060 piston to head will give you no useful quench where .045 will give you good quench. However the difference in compression ratios between those two would not be significant. The quench is worth it in terms of detonation resistance, even though it'll increase your compression a tad.
I've been playing around with a desktop dyno and if its at all accurate then you'll be hard pressed to make 500 hp with the Stealth heads, they just don't flow enough.
Dwayne (fast68plymouth) flowed a set of stealth heads verus a set of e-brock rpm heads, both heads straight out of the box. Here were his numbers he posted.
4.375 bore, 28" test pressure, radius plate on intake, no tube on exhaust:
average flow for #5 and #7 cylinder
lift----I/E .100--63.8/49.0 .200-140.5/104.1 .300-207.8/139.7 .400-239.2/164.6 .450-248.1/172.5 .500-256.1/177.8 .550-261.5/182.6 .600-265.3/188.2 .650-267.3/191.5 .700-267.3/195.8
here is an OOTB E head i tested recently, also the average for a left and right cylinder:
lift----I/E .100--66.1/50.8 .200-138.3/105.4 .300-203.8/140.5 .400-243.1/163.6 .450-258.0/170.4 .500-265.7/178.6 .550-272.3/185.3 .600-276.5/190.3 .650-276.1/194.6 .700-275.7/197.3
You can see the stealths flow within +/- 4% of the RPM's across the board. So if the eddys are making 500+hp, the stealths will as well. If that's not enough for you, spend the extra 1k on sending them out to MCH for the CNC porting.
[Re: dwbiggs]
#192761
01/16/09 01:29 PM
01/16/09 01:29 PM
Posts: 4,796 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Boy the hyd flat tappet profiles sure have come a long way since the days of the 509 purple shaft or Crane FireBall series. Roller cams/lifters make more power but man the price $$$!
Keep old mopars alive.
[Re: GTX MATT]
#192763
01/16/09 05:26 PM
01/16/09 05:26 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I built my mild 440 in my 63 with parts I had that seemed to match up ok. If you punch in my just over 3700 lbs and my 116.84 mph it comes out to right about 500 flywheel hp. My 440 is basically a stock shortblock with KB quench dome pistons for open chamber heads. I used the KB pistons with the quench pad so I could get the quench pad within .042 of my cyl head for good quench. I run it at 10.0 comp using the 906 heads I ported and it runs fine on 92 pump with 36 to 38 total timing. With Eddy or Stealth heads you should definetly make more hp then my combo and I would run more like 10.5 to 11.0 comp with the aluminum heads. It would depend on the cam I used for the exact comp I would run but the aluminum heads can run about a 1/2 to 1 point more comp and still use 92 pump with the right build. But as stated the quench is very important. You could have 11.0 comp with quench and no ping and then have 9.5 comp on iron heads without quench and it might ping. You can click the link to see the build on my 63 but remember I am on a tight budget so I used alot of parts I already had. Ron http://www.1962to1965mopar.ornocar.com/mmo82008.html
[Re: 383man]
#192764
01/16/09 11:24 PM
01/16/09 11:24 PM
newbee69
North Chicagoland
Hey Thanks for the suggestions guys! These replies were just what I was looking for. I figure Ill be good with my short block. Im definitely going to look into those stealth heads. Ive already got the six pack setup. Thanks for educating me on quench and what "good" quench is. Now its just a matter of decking the block to get the proper quench, picking a nice streetable cam, and deciding if I want to go with roller rockers. Thanks guys. Ill get back with more questions as they come up.
