Let's see your small block motor plates #1926763
10/06/15 12:33 AM
10/06/15 12:33 AM
CA.
RAY1969CARS Offline OP
CA.
Who's are you running !!?? Mopar or no car.
Re: Let's see your small block motor plates [Re: RAY1969CARS] #1926792
10/06/15 01:27 AM
10/06/15 01:27 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Let's see your small block motor plates [Re: DemonDust] #1926990
10/06/15 11:46 AM
10/06/15 11:46 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
That looks nice. Is that a milled/billet piece, or a milled casting? Is it a one off?
Seems like motor plates with today's CNC stuff, they would be straightforward customer customizeable, and a profitable niche market if promoted, especially if someone had a decent library of different basic designs of various solutions, beyond the standard stuff out there today.
It's not like its 5 axis super tolerance machining, and the raw material is basically flat plate.
What am I missing, or is this already resolved that i am not aware of? work
I'm with Helmuth Hübener, and no soup is being served today.
Re: Let's see your small block motor plates [Re: RAY1969CARS] #1927442
10/06/15 11:24 PM
10/06/15 11:24 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
It's a piece of billet. There are a lot of them out there. It would be very easy to indicate all the holes and copy it. I've thought about it several times to make my own, so I could change a few things.
Each hole is helicoiled.
It's recessed for the jesel belt drive too
SDG Motorsports
Re: Let's see your small block motor plates [Re: DemonDust] #1928070
10/07/15 10:44 PM
10/07/15 10:44 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Mine was copied from a Competition Engineering piece.
I used it for a template because it had been drilled out for a lot of stuff I'd never have on my car.
A mill and rotary table helped get a nice radius on it , so it was labor intense , but turned out alright.
Re: Let's see your small block motor plates [Re: RAY1969CARS] #1928120
10/08/15 12:07 AM
10/08/15 12:07 AM
AndyF Offline
AndyF  Offline
Here are a couple of different options
Re: Let's see your small block motor plates [Re: RAY1969CARS] #1930005
10/11/15 01:51 AM
10/11/15 01:51 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Nice pieces out there !!
Dou you install a rear piece too ?
Can you get rid of the heavy K member when bolting the plate to the front frame rails ?
Re: Let's see your small block motor plates [Re: AndyF] #1942539
10/31/15 09:09 PM
10/31/15 09:09 PM
CA.
CA.
Any one using studs !?
