Page 1 of 3 1 2 3
Replaced a Posi with a spool now the car moves around #1926165
10/05/15 12:21 PM
10/05/15 12:21 PM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
So went from a Posi and stock axles to a Strange spool and axles this past winter on my Mom's bracket Duster. Now the car is un stable going down the track. It just moves around and searches a lot. I thought maybe the spool was highlighting the fact that the frontend didn't have much caster so I rebuilt the frontend with all new ball joints, tie rod ends, and new QA1 upper control arms with 3.5 degrees of caster. This didn't change the way the car handles at all. It has old Comp Engineering shocks on the back with HD springs and the front has some old Koni shocks. All the suspension and tires have been on the car for a while and the only change that seemed to cause this problem was the spool and axles. Any ideas what may be causing this issue?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926174
10/05/15 12:29 PM
10/05/15 12:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
What tires are on the front and back of the car?
Have you measured the circumference of the rear tires?
Is the rear of the car sitting much higher than the front?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926178
10/05/15 12:36 PM
10/05/15 12:36 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Is it an 8-3/4 ?? did you check to see if the housing is bent?
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926182
10/05/15 12:46 PM
10/05/15 12:46 PM
Mansfield, Tx
Mansfield, Tx
It has M/T ET fronts and M/T slicks. They can from the M/T truck and were matched when new to 1/4" of rollout. The rear does have some rack to it being a stock suspension car. It does have a 8 3/4 rearend in it. I haven't measured to see if it is bent but the old axles came out very easily and the new ones went in very easily.
The really weird thing is it doesn't go right or left every time. It leaves straight and then just starts to sashay around.
14x Track Champ
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926195
10/05/15 01:05 PM
10/05/15 01:05 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
what did the clutches look like?
one tire may have been spinning less than the other.
check circumference again.
Don
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926204
10/05/15 01:22 PM
10/05/15 01:22 PM
Mansfield, Tx
Mansfield, Tx
I will check the slicks again but wouldn't that cause the car to pull one way or the other? This car sways back and forth all the way down the track until you let off the gas.
14x Track Champ
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926205
10/05/15 01:22 PM
10/05/15 01:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check air pressure it's probably low
Re: Replaced a Posi with a spool now the car moves around [Re: Quicktree] #1926215
10/05/15 01:46 PM
10/05/15 01:46 PM
Mansfield, Tx
Mansfield, Tx
Air pressure is checked before every run in all 4 tires.
14x Track Champ
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926229
10/05/15 02:05 PM
10/05/15 02:05 PM
Locomotion Offline
Locomotion  Offline
FWIW, I'm also wondering if the housing is "tweaked" and/or is the rear is "square" in the chassis. But whatever it is, it seems like the Sure-Grip was absorbing some of the problem through slippage and the spool doesn't.
Strut rods and steering box tight?
The only time I had a wandering problem was when I tried 165/15 radial front tires on my bracket car.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926234
10/05/15 02:14 PM
10/05/15 02:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
tires growing at different times
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926239
10/05/15 02:21 PM
10/05/15 02:21 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
With it going both directions an arbitrarily moving each direction I would look real hard at the housing. It sounds to me like each slick is trying to force the direction of the car going down track. I would not think that it would take much to cause a problem.
Getting old just means you were smarter than some and luckier than others.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926240
10/05/15 02:22 PM
10/05/15 02:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the exact same combo on the street and it`s a wandering fool for sure.........
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926284
10/05/15 03:09 PM
10/05/15 03:09 PM
Mansfield, Tx
Mansfield, Tx
What is the best method to measuring to see if the rearend is square?
14x Track Champ
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926289
10/05/15 03:23 PM
10/05/15 03:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Find the factory jig holes in the frame and measure to the housing
Re: Replaced a Posi with a spool now the car moves around [Re: sixpackgut] #1926306
10/05/15 03:44 PM
10/05/15 03:44 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Check the rear spring front bushings to see if they are loose.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926424
10/05/15 06:23 PM
10/05/15 06:23 PM
Washington
madscientist Offline
Washington
When they hunt like that something is moving.
I bought a set of SS springs (way back in the day) off a dude with the hangers and everything. Just bolted them in. After damn near getting the tree, the left guardrail, back over the center line, back to the left guardrail, back across the center line and almost into the door of the dude in the right lane I lifted.
25 different pit heros tried to tell me the front end was jacked up, but I kept telling them every time I shifted or lifted it changed directions. I spent a considerrable amount of money on the front end but still, you NEVER knew which way you were going.
I caught it by plumb bobbing off the axle faces and measuring to find that the axle was not square in the car. I started taking stuff apart and that's when I found out the dude used bolts that were too small in diameter throught the front spring eye! So literally, every time you changed load (shifted, lifted, braked etc) the axle could move front to rear in the car. Sometimes the wheel base would be longer on the right and shorter on the left, or it could be shorter on the right and longer on the left.
I ran into the dude several years later and he told me that's why he sold them.
So any time they move around like that I look to the rear end.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926458
10/05/15 06:57 PM
10/05/15 06:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A non square housing will cause the car to dog track. A bent housing that has toe-in or toe-out will drive very poor. I've driven cars that were in accidents prior to doing the alignment. Those with bent rear housings would drive similar to driving a boat. It feels like it steers from the rear and very twitchy. If everything is tight I would definitely check the rear toe.
Doug
Re: Replaced a Posi with a spool now the car moves around [Re: Dodgeguy101] #1926788
10/06/15 02:08 AM
10/06/15 02:08 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Agree front bushings could be loose or worn. I use aluminum front bushings on my rear springs.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926851
10/06/15 08:25 AM
10/06/15 08:25 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the question is how much pressure. I see so many people running way to low of air pressure. if your sure about everything else try raising the rear pressure up a little at a time.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1926852
10/06/15 08:28 AM
10/06/15 08:28 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
If the only change is the spool it would have to be in the tires.
I suspect one is larger than the other, run into this myself. I lost a slick at an event and had to pop on a backup and the car walked around like crazy.
"I think its got a hemi"
Page 1 of 3 1 2 3
