Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: skicker] #1926888
10/06/15 10:30 AM
10/06/15 10:30 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
This chart may help with what you need. Looks like 51.4" to the housing flange? shruggy http://www.mymopar.com/forum_images/rearaxledims.jpg
...FAFO...
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: skicker] #1927109
10/06/15 03:48 PM
10/06/15 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
GAWD!!! I wish someone would outlaw that chart, it's everywhere and mostly wrong.
All '66-'72 A-body housings are 52 5/8" wide. Using the BBP axles in an A-body housing will increase the overall width 5/8" so, to keep the original overall width, you'd have to make the housing 52.0".
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: John_Kunkel] #1927312
10/06/15 09:34 PM
10/06/15 09:34 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
John , thank you. What is it about the BBP axles that make it 5/8" wider?
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1927493
10/07/15 02:03 AM
10/07/15 02:03 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Total brake offset for '65 and newer 5 x 4.5" Mopar axles measures 2.525" when installed. The 5 x 4" version measures 2.25".
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: DoctorDiff] #1928014
10/07/15 10:24 PM
10/07/15 10:24 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Thank you Dr. Diff.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: DUSTER_340] #1928831
10/09/15 02:56 AM
10/09/15 02:56 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Not to rob Cass of any business, but I would respline a set of C body axle shafts just like I would bore and reuse a 40-50 year old engine block or crank. Why? It's cheap and more importantly I'M CHEAP!!! laugh An hour of shop time compared to brand new shafts? Unless you are going to stand on this car, I don't see any reason not to give grandpa's old axles a new lease on life.
Mopar Action did a great story on this back in the 90's and it's likely available at their website. I got mine out of a 69 Fury. Go for it. If you can't get the thing together, call the Dr.
I’m listening.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1929013
10/09/15 01:55 PM
10/09/15 01:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So, how much does it cost for someone to respline a set of axles? You have to figure in shipping both ways too. Not everyone has someone close by that can/will do it.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: burdar] #1929016
10/09/15 02:01 PM
10/09/15 02:01 PM
RapidRobert Offline OP
Moser in Portland Indiana. $125 (per pair) plus the ride (both ways)
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1929113
10/09/15 03:57 PM
10/09/15 03:57 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
another vote for dr diff
I used to respline them back in the day
cheaper to buy them from the dr and your done with studs & brgs.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: 440farmer] #1929122
10/09/15 04:11 PM
10/09/15 04:11 PM
If I didn't already have em I would call the Doc
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1929148
10/09/15 05:22 PM
10/09/15 05:22 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Back in the day when I worked in the wrecking yard we used to mark the end of the aisles with axles that we would pound in the ground and spray paint with fluorescent colors. When we finally closed the yard, we crushed all the cars that were left, pulled the axles out of the ground and sent everything to the scrap mill. The C body axles were a favorite for the task because we had so many of them and they never sold.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: Polarapete] #1929268
10/09/15 09:17 PM
10/09/15 09:17 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
You should send that sign over to the parts store post in the general section... biggrin
...FAFO...
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: skicker] #1929381
10/10/15 12:21 AM
10/10/15 12:21 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Glad you liked it, feel free to use it when it seems right!!!
2008 Honda Element
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: skicker] #1929467
10/10/15 09:15 AM
10/10/15 09:15 AM
Washington/Las Vegas
1971 Gran Coupe Offline
iagree iagree iagree laugh2
