Which header paint and what color???? #1924520
10/02/15 10:40 PM
10/02/15 10:40 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I have a stock'ish appearing 440 engine that I am using headers on. The ceramic had started to rust so I blasted them and will paint them. What color will look good with a stock engine and what paint do you like?
Re: Which header paint and what color???? [Re: BPBP440] #1924523
10/02/15 10:45 PM
10/02/15 10:45 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My TTI headers are ceramic coated, but some spots wore off during some aggressive cleaning. I sprayed VHT silver (A close match in color) and I like it. Later, I pulled the headers and cleaned them with Acetone and a scotch brite, then resprayed them both entirely with the VHT, not just the places I wore off the ceramic coating. They have held up fine with zero peeling. Now I find and stop oil leaks before they can stain the headers!
Re: Which header paint and what color???? [Re: Kern Dog] #1924554
10/02/15 11:26 PM
10/02/15 11:26 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Another vote for VHT, I have used their coatings for many years and have been ecstatic with the durability. The only Ceramic coating that I have found comes close or worthwhile it JETHOT. We just had a set of headers done by a reputable local coater and they have discolored a bit near the exhaust ports on 3 cylinders with no apparent reason. ARRRGGGHHHH should have sent them to Jet hot or used VHT. twocents spank
Re: Which header paint and what color???? [Re: BPBP440] #1924576
10/02/15 11:46 PM
10/02/15 11:46 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Been having good luck(and longevity)with VHT ceramic header 'paint'...
Re: Which header paint and what color???? [Re: BPBP440] #1924601
10/03/15 12:18 AM
10/03/15 12:18 AM
BPBP440 Offline OP
BPBP440  Offline OP
Great, sounds like VHT. Wondering what will look best.... Silver, Black, Cast Gray....
Re: Which header paint and what color???? [Re: BPBP440] #1924616
10/03/15 12:34 AM
10/03/15 12:34 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Don't know, but I have always used SP117 Flat aluminum twocents
Re: Which header paint and what color???? [Re: BPBP440] #1924803
10/03/15 11:15 AM
10/03/15 11:15 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I have used Rustoleum BBQ paint in both black and silver. It tolerates heat well, but doesn't seem very resistant to chemicals (which ones I don't know, I just know some had rubbed off of my headers where I think I splashed some oil or gas).
For the difference in the price of a can, I'll probably use the VHT next time just to see if it's any better.
Re: Which header paint and what color???? [Re: TJP] #1925444
10/04/15 10:27 AM
10/04/15 10:27 AM
BPBP440 Offline OP
BPBP440  Offline OP
Great. I had actually purchased VHT flat aluminum before I created this post. I'll go with it. Thanks.
Re: Which header paint and what color???? [Re: BPBP440] #1925551
10/04/15 01:30 PM
10/04/15 01:30 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
3 or 4 thin coats is better than heavy ones. beer
Re: Which header paint and what color???? [Re: TJP] #1925712
10/04/15 06:49 PM
10/04/15 06:49 PM
BPBP440 Offline OP
BPBP440  Offline OP
Bought the primer too. What do you think about that? Worth the effort/$?
Re: Which header paint and what color???? [Re: BPBP440] #1925834
10/04/15 10:29 PM
10/04/15 10:29 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Hmm Duuno ? Always put it over a well prepped surface. Think bare, blasted metal or sometimes, just scuffed, degreased
(think, prep, acetone, alcohol wipe down, unless the coating was thick, then BLAST and paint.
Never used the primer. shruggy twocents
Re: Which header paint and what color???? [Re: TJP] #1925863
10/04/15 11:11 PM
10/04/15 11:11 PM
BPBP440 Offline OP
BPBP440  Offline OP
These are freshly media blasted, so I'll wipe them down good and they should be ready. Not only do they recommend the primer on the back of the paint can, but the hi-temp clear coat too. I might do that depending on the finish I get.
Re: Which header paint and what color???? [Re: BPBP440] #1925873
10/04/15 11:25 PM
10/04/15 11:25 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've had great luck with Eastwood bright silver header paint, also had good luck with Rustoleum black BBQ paint.
Re: Which header paint and what color???? [Re: ProSport] #1925888
10/04/15 11:31 PM
10/04/15 11:31 PM
BPBP440 Offline OP
BPBP440  Offline OP
Good to know. I often buy Eastwood products and using their header paint was my original plan. I got too eager too wait so ended getting some VHT from the auto parts last week. Unfortunately it got too cold to paint here this weekend, so I may still order from Eastwood.
Re: Which header paint and what color???? [Re: BPBP440] #1925923
10/05/15 12:14 AM
10/05/15 12:14 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's the Eastwood paint on my old 69 Dart, it never faded or changed color even on a 9 second car. It's very easy to touch up with a sponge type paint brush. You get enough paint in the can to do about 10 sets of headers!
Re: Which header paint and what color???? [Re: ProSport] #1925930
10/05/15 12:23 AM
10/05/15 12:23 AM
BPBP440 Offline OP
BPBP440  Offline OP
Nice looking motor. What valve covers are those? I posted a question about the 440 source cast polished covers earlier and they look very close to those.
Re: Which header paint and what color???? [Re: ProSport] #1925974
10/05/15 01:27 AM
10/05/15 01:27 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Headers look great...I've like the results using the eastwood paint also..Prep is the key with any brand..Easy touch-ups are a big plus here in Rustylvania
Re: Which header paint and what color???? [Re: BPBP440] #1926100
10/05/15 10:39 AM
10/05/15 10:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
VHT semi-gloss black. It works very well even for people like me that didn't follow the directions. You do have to strip all the factory paint of 1st.
Coming soon!!!!
Re: Which header paint and what color???? [Re: BPBP440] #1926192
10/05/15 01:00 PM
10/05/15 01:00 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Myself, we have always just done the paint on a clean dry well prepped base. The VHT is also very easy to touch up if needed. I wouldn't be a bit surprised if Eastwood gets their paint from VHT as the pic posted looks very similar. One of the guys that works here tried the clear coat on his white headers and it worked well but yellowed the color. beer
Re: Which header paint and what color???? [Re: TJP] #1926327
10/05/15 04:13 PM
10/05/15 04:13 PM
BPBP440 Offline OP
BPBP440  Offline OP
Good to know about the clear coat.
