Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1922994
10/01/15 01:19 AM
10/01/15 01:19 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Lookin good!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1924220
10/02/15 03:32 PM
10/02/15 03:32 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Good luck on it! If you have any questions feel free to give my old man a call as we have finished up our alluminum ritter block engine. The last issue we had, and hopefully we can help you avoid with yours was oil drain back to the pan from the valley. The enclosed cam tunnel with small drain backs is not enough and after a short time on the engine dyno the pan was empty. We had to disassemble it, and put better drain back passages in it, and it is happy now. A lot of hours chewed up though.
Wayne @ Joss Engines. 1-403-320-7272
-Kenny
Re: 420cid build with a new Ritter Aluminum Block [Re: StrokerAspen] #1924486
10/02/15 09:56 PM
10/02/15 09:56 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I have the first aluminum 9.600 xr2 that I am doing now.Hope to post some on here of it as we make progress.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1924524
10/02/15 10:46 PM
10/02/15 10:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That's super cool, hope it works out for you. Should be mean!
Re: 420cid build with a new Ritter Aluminum Block [Re: 1967dartgt] #1924540
10/02/15 11:02 PM
10/02/15 11:02 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Thanks Brad.I hope it works out good too.I was told the aluminum block doesn't have the core shift like the cast blocks.
Re: 420cid build with a new Ritter Aluminum Block [Re: bdaz smblk] #1925075
10/03/15 06:28 PM
10/03/15 06:28 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
I for one would like to see everyone make a go of these blocks.if kent and everyone else involved with these are at least willing to invest their time and money to come up with a viable solution to mopar not being able to supply blocks for the performance side then I applaud their efforts.sure with his stockpile of parts he stands to make financial gain but they are the ones that stuck their necks out to get this far.nothing that is as innovative as trying to do a block to cover such a broad array of heads and combos will come without large growing pains but without a couple brave souls who work thru these problems nothing will be accomplished.maybe the ones who have been there and done that can help others who are willing to give it a go .we will see how things work out and be more than helpful to others who try if we can
Re: 420cid build with a new Ritter Aluminum Block [Re: webemopes] #1925088
10/03/15 06:51 PM
10/03/15 06:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
iagree but I wanted to see what kind of money
it would take to get it to a running block.. so far
it doesnt look bad... drain back seems to be the big
issue... I'd like to see how they corrected that...
the pick up issue is nothing.. but glad it was brought
up so people know of it
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1925148
10/03/15 08:42 PM
10/03/15 08:42 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Ask Jeff Allison he had a great amount invested in his as far as I know got nothing in return except a nice boat anchor
Re: 420cid build with a new Ritter Aluminum Block [Re: scottb] #1925151
10/03/15 08:49 PM
10/03/15 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was his the iron or alum block
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: MR_P_BODY] #1925164
10/03/15 09:11 PM
10/03/15 09:11 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
He has an iron block as I did too. I returned mine. I had a long talk with lawndart. His block looks like there have been corrections that the iron blocks had. He made his own drain bad holes in the valley, not a big deal.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1925179
10/03/15 09:27 PM
10/03/15 09:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Whitedart has the only running iron block that I know of.
Re: 420cid build with a new Ritter Aluminum Block [Re: StrokerAspen] #1925345
10/04/15 01:27 AM
10/04/15 01:27 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
-Kenny. I think you should disclose all the issues with the block as soon as possible like now.. this would help those that are trying to build succeed.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1925956
10/05/15 12:58 AM
10/05/15 12:58 AM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
I am keeping a list with pictures of all of the things that we (my machinist and I) would like to see changed on this block.
I had a long phone conversation with Wayne last Friday about all of the things he did to get the first prototype block running. Very smart man. After talking to Wayne it sounds like my block and the block he machined up have all of the same problems. After I get this thing running I will be contacting Kent and see if we can get these problems solved. It seems that most of the problems are in the machining of the block.
Thanks for all of the input on this project.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1926014
10/05/15 02:54 AM
10/05/15 02:54 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Subscribed.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1926271
10/05/15 02:55 PM
10/05/15 02:55 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
What is the weight of the aluminum block with main caps and a ball park price? I wonder if this would be good for a road race block....
A new iron curtain drawn across the 49th parallel
Re: 420cid build with a new Ritter Aluminum Block [Re: 67autocross] #1929160
10/09/15 05:48 PM
10/09/15 05:48 PM
Alberta Canada
Alberta Canada
-Kenny.
I will do what I can next week hopefully.
Shipping weight was 94lbs. with no sleeves in the block. IIRC the price was similar to an R3 with out the sleeves in the XR block.
-Kenny
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1940980
10/29/15 12:52 PM
10/29/15 12:52 PM
Pennsylvania
P
P7 Engineering Offline
P
Pennsylvania
My Brother was up at Kent's this weekend getting some stuff and was getting an update on the blocks. Kent said he got the block approved by NHRA for stock and SS racing. My brother has two blocks on order: An aluminum XR2 for P7 heads. It has been cast and machined and is getting sleeves in right now. And the second is an iron XR1 48 degree. It is to be cast with the next pour at the end of November 2015. Machining to be done in December 2015. I will let everyone know how they turn out.
My 1974 2WD shortbed Chevy Truck build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=525098
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1941110
10/29/15 05:07 PM
10/29/15 05:07 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What's the aluminum one cost machined and sleeved? I'd like to do a big inch P7
Re: 420cid build with a new Ritter Aluminum Block [Re: SpareParts] #1941302
10/29/15 10:16 PM
10/29/15 10:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
We are still talking about lifter valley drainback?
The R2 and R3 blocks had no drainbackbuilt in. It's not the enclosed tunnels fault. On the R blocks you can expose the cam and the oil drains on the spinning assembly if that's OK with the builder. On R5 or the XR blocks you have to open the bottom of the cam tunnel as well with wet sump. The R5's have been converted using 3/4" holes on either side of cam bearings to drain oil.
On R block I drained around distributor and using stock drain holes to drain behind belt drive. Trick is the heads need to drain seperate with that limited drainback around lifter valley. Haven't seen that on R5 or XR. I run R5 with dry sump, haven't needed to experiment this.
If you like swiming in oil, limit your drainback and add oil to keep from starving, NOT. Don't skimp making drainback passages. Wonder if anyone ever thought of plumbing a secondary pickup plumbed to rear of cam tunnel. May be a disaster. May work.
Re: 420cid build with a new Ritter Aluminum Block [Re: Leon441] #1941428
10/30/15 12:36 AM
10/30/15 12:36 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Two stupid questions.....What is the difference between the XR1 and the XR2 aluminum blocks?
And what heads are you guys typically running on these?
