Re: shorten C body 8&3/4 axles to fit A body housing ?
[Re: skicker]
#1927109
10/06/15 03:48 PM
10/06/15 03:48 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
GAWD!!! I wish someone would outlaw that chart, it's everywhere and mostly wrong.
All '66-'72 A-body housings are 52 5/8" wide. Using the BBP axles in an A-body housing will increase the overall width 5/8" so, to keep the original overall width, you'd have to make the housing 52.0".
[Re: DUSTER_340]
#1928831
10/09/15 02:56 AM
10/09/15 02:56 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Not to rob Cass of any business, but I would respline a set of C body axle shafts just like I would bore and reuse a 40-50 year old engine block or crank. Why? It's cheap and more importantly I'M CHEAP!!! An hour of shop time compared to brand new shafts? Unless you are going to stand on this car, I don't see any reason not to give grandpa's old axles a new lease on life. Mopar Action did a great story on this back in the 90's and it's likely available at their website. I got mine out of a 69 Fury. Go for it. If you can't get the thing together, call the Dr.
I’m listening.
[Re: burdar]
#1929016
10/09/15 02:01 PM
10/09/15 02:01 PM
RapidRobert
Moser in Portland Indiana. $125 (per pair) plus the ride (both ways)
[Re: 440farmer]
#1929122
10/09/15 04:11 PM
10/09/15 04:11 PM
RapidRobert
If I didn't already have em I would call the Doc
[Re: RapidRobert]
#1929148
10/09/15 05:22 PM
10/09/15 05:22 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Back in the day when I worked in the wrecking yard we used to mark the end of the aisles with axles that we would pound in the ground and spray paint with fluorescent colors. When we finally closed the yard, we crushed all the cars that were left, pulled the axles out of the ground and sent everything to the scrap mill. The C body axles were a favorite for the task because we had so many of them and they never sold.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: skicker]
#1929381
10/10/15 12:21 AM
10/10/15 12:21 AM
Polarapete
Graham, WA
Glad you liked it, feel free to use it when it seems right!!!
